changing the time on the instrument cluster
I'm noticing that I'm missing quite a few menus which are listed in the manual... The other menu I don't see is "Lighting" but that's another story.
Does the Canadian version of the instrument cluster have less options? I should mention that I did import my car from the US into Canada, and one of the RIV requirements was to change the US instrument Cluster to a Canadian Instrument Cluster.
Anyone have any thoughts? I hope I don't have to bring it to the stealership for a simple time change....
there is no time or lighting option
Using multifunction steering wheel
Locate "Page" button (1) on left side of steering wheel.
Press the reset button for three seconds.
Locate the "Up arrow" button (3) on the left side of the steering wheel.
Press the "Up arrow" until the words "Settings" appears in the instrument cluster screen (2).
Select time submenu then press up arrow.
Adjust hours setting using the "+" or "-" buttons (4) located on the right side of the steering wheel.
To adjust minutes, press the "Up arrow" until the words "Clock, minutes" appear in the instrument cluster screen.
Adjust minutes using the "+" or "-" buttons located on the right side of the steering wheel.
To finish, press reset stalk (5) located on the left side of the dashboard.
