Need help with 08' CLK350 wheels
I have a new 2008 CLK350 with the AMG appearance package.
It comes stock with 17" wheels.
I see alot of you guys are running 18"+ wheels. However, I tried putting an 18" wheel on my car today (from an 05' SL) and it didn't fit.
Even with the OE 17" wheel, I don't have that much clearance between the tire and the bottom of the front suspension.
How do you get 18's on this car? Do you have to go ultra low profile? Or are you modifying the suspension?
Thanks!
Ryan
According to what you are trying out, SL wheels, they won't fit. The SL's share different offsets and if I am not mistaken longer lugs. Try finding a set off of a C, CLK or SLK which are all bolt on's to our car.
Good luck!
Generally, when going to 18's the profile drops 5% per inch and the clearance stays the same.
That SL wheel has the wrong offset for your CLK ... so don't use it!
Good Luck!
