Interior lighting....
Old Feb 6, 2010 | 10:02 AM
Rashman's Avatar
Mercedes-Benz CLK63 AMG Coupe
Hey guys.
I have some LED bulbs that I want to install.
I finally worked out how to remove the lense cover of the light up near the rear-view mirror. There's just one bulb up there.
But.
I couldn't work out how to remove the cover that sits over the rear bulb above the rear seats.
I thought this one would be easy, as it's the same design as the 208.
Does anyone have a tip on how to remove this?
I believe one end of the cover is hinged. So when you remove the free end, it just swings down so you can change the bulb.
This one's stuck fast though.
I can managed to release the un-hinged end by about 3mm, but then it won't free up any more than that. It seems to still be clutching to it's friction clip
Thought I'd ask before I approach it alittle more heavy-handedly!
Cheers guys.
Old Feb 6, 2010 | 10:54 AM
Rashman's Avatar
It's ok guy.
I've done it!
Thanks, anyway.
Old Feb 11, 2010 | 12:50 PM
Aisamasa's Avatar
CLK 320
Hi,
what kind of led-bulb did you use on dome-light?
As the problem with the smd-leds seems to be that the light doesnt completely shut off, but leaves a dim light that stays on all the time when driving.
At least that was the problem i had when tried to replace a filament bulb with led.
Old Feb 11, 2010 | 01:05 PM
Rashman's Avatar
Originally Posted by Aisamasa
Hi,
Yeah, this problem has been mentioned before.
I don't know exactly what type of LED's I have, but they are 12 volts bulbs.
There is only one bulb up in the dome.
I have used a festoon style bulb with 6 LED's in it. Arranged like a dice.
The one above the rear seats is the same.
For the under-door lights, I used a "wedge base" bulb with a cluster of 4 LED's.
When I lock the car, the LED's stay on (emitting a soft glow) for about 2 mins. Then they go out.
But I have not driven the car yet, so I cannot confirm whether they stay on when I'm driving.
I'll let you know as soon as I drive it.
I'll take some pics of the bulbs ( I have some spare) later on and post them up.
Just gonna wax the car.
Old Feb 11, 2010 | 03:08 PM
Aisamasa's Avatar
CLK 320
Yup, Seem to be doing the same thing as mine did when shutting the doors, so im afraid they will stay on while driving too. Thats rather annoying and the light prevents the rearview mirror sensor working too.
I tested the ones with resistors too if that would help, but no luck.
I hope someone finds the answer because those led festoons would look so cool
Old Feb 11, 2010 | 03:17 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
My door LED's stay on while I'm driving. I bought all my interior lights from superbrightleds.com and have had no problems
Old Feb 11, 2010 | 04:04 PM
Rashman's Avatar
I'm back.
Car is nice and waxey!
Here's a couple of pics of my LED's.
The long one with 6 LED's is the Festoon style bulb.
The other is the "wedge base" LED with a cluster of 4 LED's.
I'm soooooo hoping they go out when I'm driving!
Attached Thumbnails Interior lighting....-led-1.jpg   Interior lighting....-led-2.jpg   Interior lighting....-led-3.jpg
Old Feb 11, 2010 | 06:44 PM
guofan's Avatar
W209 500
I recently installed LEDs for my interior as well. The LEDs in the door turns off, but blinks even after I lock the car. Then I changed them out with a 1 bulb LED instead of 3 bulb LED, the blinking stopped. You really don't want the LEDs to stay on, even though LEDs requires very little voltage, it still drains on your battery.
I rather have the oem bulbs back on if they stay on. Maybe you can try to use a LED that consists of less bulbs.
Old Feb 11, 2010 | 06:46 PM
Rashman's Avatar
Originally Posted by guofan
I recently installed LEDs for my interior as well. The LEDs in the door goes off, but blinks. Then I changed them out with a 1 bulb LED instead of 3 bulb LED, the blinking stopped. You really don't want the LEDs to stay on, even though LEDs requires very little voltage, it still drains on your battery.
Yeah, that's true.
I'll be putting my original bulbs back in if the LED's give me any problems.
Old Feb 11, 2010 | 08:08 PM
M-bENZ's Avatar
Corrolla
If you not gona drive your car for like 2 or 3 months then those LED under the door will be good.
Andy
Old Feb 12, 2010 | 12:59 PM
Rashman's Avatar
Andy
Hi mate,
How do you mean?
Old Feb 13, 2010 | 02:23 PM
Rashman's Avatar
Right.
I managed to get the car out today.
Woohoo!
Car rocks.
Anyway, it appears that my newly installed LED's prefer to stay on when the car is in operation. Not on fully, but emitting the soft glow.
However, they are happy to turn off completely when I lock the car.
This I am glad about.
Pretty weird that they don't go out completely when they should.
I may leave them in as I really like the blue lighting.
I'll see how it goes.
I may find myself getting pulled over with the soft glow during driving!
LOL
Old Feb 13, 2010 | 06:04 PM
M-bENZ's Avatar
Corrolla
is your LED really that bright while your car moving ? It happened the same to me but mine is not that bright thou.
Andy
Old Feb 13, 2010 | 06:23 PM
Rashman's Avatar
Andy
No, they're not that bright at all.
But you'll probably be able to see them if you were in the car behind though.
During the day, they're hardly noticable.
I'll have to see how obvious they are when I next take it out at night.
Old Feb 13, 2010 | 09:06 PM
M-bENZ's Avatar
Corrolla
Ok I just checked mine...The LED is on ( you can not see from the rear) while im driving too but when you lock it its gone...that IS WHAT i want lolz.
Andy
Old Feb 13, 2010 | 09:22 PM
guofan's Avatar
W209 500
hmm. Weird LEDs.
Old Feb 14, 2010 | 06:03 AM
Rashman's Avatar
Yeah, it is pretty strange behaviour.
But I'm with Andy for now.
I'm happy that they go off when I lock the car.
As long as they don't generate too much heat while in their "dim" state, then I may well leave them as they are.
Old Feb 14, 2010 | 10:53 AM
M-bENZ's Avatar
Corrolla
We are good Rashman .
Andy
Old Feb 14, 2010 | 11:02 AM
Rashman's Avatar
Andy
Cool, cool.
But if my car catches fire, I'm huntin' you down.
Old Feb 14, 2010 | 11:08 AM
M-bENZ's Avatar
Corrolla
ahhaha your up early .
Andy
Old Feb 14, 2010 | 11:11 AM
Rashman's Avatar
Andy
LOL!
Early?
It's bloody 4pm over here!
LOL
Old Feb 14, 2010 | 11:13 AM
M-bENZ's Avatar
Corrolla
ooops my bad ...forgot your in UK LOL.
Andy
Old Feb 14, 2010 | 11:15 AM
Rashman's Avatar
Andy
LOL!
Morning buddy.
Have yourself a coffee.
Old Feb 16, 2010 | 11:51 AM
astropat's Avatar
CLK 320
Did you guys replace the map lights? I was trying to get in there yesterday and couldn't figure it out. I was shoving a little screwdriver all over the place after I got the dome cover off.
EDIT: I came across this again... I'm going to prod some more, but have you guys actually replaced the bulbs and got them to work?
Old Feb 16, 2010 | 12:58 PM
Rashman's Avatar
Hey bud.
You may want to leave those map lights.
I thought about changing them too, but I don't really use them ever.
Also, if you're not sure how to get it open, it usually ends up with prodding away with a screwdriver etc.
Decide how much you want them changed first.
That's the principle I try to use.
The last thing you want is loads of scratches and digs everywhere.
Just a thought, bud.
As for the other bulbs, yeah they work, but seem to like staying on during journeys.
