those of you with aftermarket audio systems
2018 E43 | 2017 GLS450 | 2004 CLK 500
what did you do with the rear speaker? I installed some Focal coaxials running full range, but I'm basically fading my system 75%-80% front so I hardly use them. So my system is mostly my front Focal separates, and my rear sub. Just curious how everyone else set theirs up.
When I had my 2001 CLK430...I just ran MBQuart coaxials...
I put JL Audio C5-650 in the front and C5-650x in the rear. They add fill although I could have gone with a less expensive model, and achieved the same effect. I have JL Audio 13TW5 sub mounted in the trunk to fill in the BASS.
How's your trunk space? Did you use some stealth enclosure? I have a JL 10w6v2 in a sealed box. Still takes up too much space.
Sorry about the pics! I downloaded them from the facebook site and must have resized them. Here is the link to the install, and better pictures.
http://www.facebook.com/album.php?ai...id=55338502377
04 CLK 320 > CLK32K
Very Nice!! How does it sound? Does the sub rattle the glass in the back? Do you know how much you spent in Dynamat? How about the whole install?
Sounds AWESOME now! had to tune the EQ, also had a wiring issue with a rear speaker; that kinda screwed up everything due to the summing of the input signals to the EQ. Doesn't really rattle the window, and the bass was way more than I was expecting. I think we spent somewhere around 250-500 for the dynamat. The install was done in pieces. The part you can't see from the pictures was the MoBridge bluetooth/ipod adapter install. Then we replaced the front & rear speakers, and then finally were the amp, eq, and sub. I would say it cost somewhere south of 6K.
04 CLK 320 > CLK32K
6k WOW
I can believe that it would cost in that ballpark area of 6K. I bought some most of my parts used and didn't even upgrade the speakers yet... and no custom enclosure... didn't use dynamat and I spent almost 2K.
Ideally, I'd want to install the sub where the factory sub is and find a better place to hide the amps. My 4 channel JL is huge.
Yes, 13TW5 is very nice. I was very worried when we first discussed installing it. I have a 10w3 stealthbox in my Sequoia and it sounds soooo good. I was very surprised by how much bass the 13TW5 puts out. Plus being driven by the HD900/5 helps!
