Bi Xenon Headlamp
'05 CLK 320
Bi Xenon Headlamp
Hi all, new to the forum. I have a '05 CLK320 and have had a problem with my right headlamp. Low beam headlight went out and took the car in to replace the bulb but that was not the problem. One MB Dealership says its the headlamp control unit (appx $900 to repair) and another MB Dealership says its the entire headlamp that needs to be replaced ($1700).
Is there another way to remedy this problem...maybe by replacing the part with another that is not OEM? Would this work?
http://www.lightinthebox.com/wholesale-H7_c2271
Any advice would be appreciated.
Thanks! Jeannie
Thanks! Jeannie
209/W210 Estate /W211 modded by MBENZNL
Mercedes sells a repair kit for the Xenon headlights (simple to install)
If the headlight does not turn on more than likely its the ignitor
I have done several..with the kit from Mercedes...
'05 CLK 320
'05 CLK 320
One dealership said it was the ballast another said it was the entire unit.
Thanks, I'll check there
Hmm...I will call them tomorrow thank you.
