HELP PLEASE - CLK500 starting problem
Old Apr 3, 2010 | 05:18 PM
wazv6's Avatar
'14 E550
Hi guys. My car is having this wierd starting problem. When I tried starting the car it would crank but not start. I tried starting it about 2-3 times and it did not start. On the 4th try it started with the check engine light on. I drove it home and the car drove like normal. When I turned the car off and started it immediately after it would start right up with no check engine light on. Which is very wierd. Also after letting it rest for a while the problem would re occur. Any idea on what could cause this. Im thinking I may need a new starter?
Old Apr 4, 2010 | 12:10 AM
SZMB's Avatar
2004 E500 CLK320
Get a OBDII code reader and read the fault code. Some Autozone stores lend them out for free, or you can buy one for $50-$80. I've read some people had the same problem and it turned out that the CPS (crankshaft position sensor) is faulty. It's a $40 part online from autohausaz.com. But definitely get the code read first. BTW, if the engine cranks, that means the starter is doing its job -- no problem here.
Old Apr 4, 2010 | 10:33 PM
wazv6's Avatar
'14 E550
Thanks SZMB. Im going to get that code read and hopefully its the CPS that's faulty.
Old Jul 30, 2013 | 08:58 AM
Paulmonaghan1's Avatar
2003 clk. 500
Hi wazV6
Did you find the issue? This happened to me today...
Any help will be great!
Old Jul 30, 2013 | 07:10 PM
jhbrad's Avatar
E320, CLK500, Red C5 Corvette
This has happened to a lot of us, and it generally turns out that the CPS (crankshaft position sensor) is faulty. It's a $200 fix at the shop for a $40 part online from autohausaz.com. Good luck!
Old Jul 31, 2013 | 09:25 PM
Redcab's Avatar
CLK 63 AMG
I had a similar experience. My CLK (W208) would not start yet the starter turned normally. $200 later, I had a new crank positioning sensor and reliability has been 100% since. It did seem odd that the car, after sitting 1 hour, started without issue. This was especially disappointing to the flat bed driver who lost his tow fee. I was able to drive to the shop for the repair as if nothing had happened.
Starter drag was the only warning sign I ever got that the sensor was failing.
Old Jul 31, 2013 | 10:01 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
A good way to check for a bad CPS (and get going again) is to pour cold water over it. Once it's cooled, it usually start working again.
