Wheel Spacers front and rear
http://hrsprings.com/scripts/appguid...0|%20CLK%20500
Wouldn't shorter bolts fix that?
You might have a vibration problem but you don't even know it. The front suspension you can feel it more because of the steering wheel connect to the front suspension.
I dont' have the front wheel spacer, so I don't think I have the vibration problem in the front. As for the rear, so far I don't have any problem and took the car up to 130mph and the car is still running pretty smooth. So I guess I don't have the vibaration issue.
I know you don't have the spacer in the front, I'm just saying that most people feel vibration from using non-hub centric spacer when they
use it in the front. Very rare anyone can feel vibration from the rear from using non-centric is because of the steering wheel is not connect to the rear suspension. Just think about it, if most non-centric spacer cause vibration in the front but why not it the rear. believe me, it does too but you just don't feel it as much because the steering wheel is not connect to the rear suspension. If you really want to check it, have some one drive side by side and see if your wheels is bouncing of the road. Btw, vibration cause at some mph and not throught all mph. It usually happen around 60-75 mph for the front with a non-centric spacers.
