Anyone know where the Cabin air filter is?
Old Jul 24, 2010 | 05:55 PM
TheRemedy's Avatar
05' MB CLK320
I have a 2005 Mercedes CLK320, and she needs a new cabin air filter, anyone know where it is? a picture would be great.
And any good places to buy a new one?
Old Jul 24, 2010 | 06:12 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
It's under the passenger dash...These are off the WIS
Attached Thumbnails Anyone know where the Cabin air filter is?-cover.jpg   Anyone know where the Cabin air filter is?-filter.jpg
Old Jul 24, 2010 | 07:22 PM
mis3's Avatar
2004 CLK320
Mine (2004 CLK320) is located under the battery cover. I just changed it and the part no was 203-830-09-18.
Is there another air filter under the passenger dash?
Old Jul 24, 2010 | 07:43 PM
bheng's Avatar
2003 CLK 320
there is a filter under the passenger side which is what Wes put up. and there is another one that you replaced above the battery.
Old Jul 24, 2010 | 10:45 PM
mis3's Avatar
2004 CLK320
Not sure if this one, under the passenger dash, was ever changed in my car.
Do you have the part number?
Old Jul 25, 2010 | 03:22 PM
TheRemedy's Avatar
05' MB CLK320
ah gotcha, thanks! I'll switch it after my vacation
Old Jul 25, 2010 | 08:24 PM
jawsplace's Avatar
1992 400SE, 1997 S500 Coupe, 2019 C300 4MATIC
The cabin air filter is housed inside the battery cover on the passenger side, under the hood. 3 latches hold it on. Easy to take off. There's a large, rectangular, pleated paper filter there. Just pull it out and replace with a new one. Very easy.
The filter under the dash is the active charcoal filter. I don't think this needs to be changed.
Old Jul 25, 2010 | 08:41 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Yup, you are correct. My bad, didn't even notice it said Charcoal
Old Jul 25, 2010 | 08:44 PM
M-bENZ's Avatar
Corrolla
what will happen if we take the charcoal filter out (the one under the passenger dash) ?
Andy
Old Jul 25, 2010 | 08:51 PM
jawsplace's Avatar
I don't think there's any problem if you do remove the charcoal filter unit but I'm not sure that it's designed to be "servicable". I doubt there's anything you can actually replace from inside it. The active charcoal captures odors and any noxious gasses before they can enter the cabin (especially if you're in a smog ridden city). It never sees any dust or dirt. If for some reason it needs attention I think you'll be faced with having to buy the entire charcoal filter assembly. I'm sure it's not cheap like the paper cabin filter. I won't go through the hassle of taking it out unless you're sure there's something wrong with it.
Old Jul 25, 2010 | 11:33 PM
M-bENZ's Avatar
Corrolla
Good info. . I wont touch it lolz.
Andy
Old Sep 23, 2018 | 07:26 PM
Dom Salustri's Avatar
2005 CLK350 & 2004 ML350
2005 CLK320 Inside Cabin Charcoal Air filter
I took down the under dash panel trying to change the charcoal filter but much to my surprise all that is the next to the blower motor is a huge block of styrofoam. I took down the driver's side to check there but nothing.
the duct comes out of the blower motor but there doesn't seem to be a filter in line, is that possible? Where else can it be located?
Old Sep 23, 2018 | 09:49 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
The CLK350 does not have the charcoal filter, only the V8s with the advanced ACC system have it. Your CLK350 only has the pollen filter, located under the hood, passenger side, above the battery.
