Fuse Box Layout for W209
can anyone point me towards a fuse box diagram / allocation list for a W209?
I have a 2007 CLK 200 Convertible and the cigar lighter fuse is blown. I know its in the fuse box under the hood but have no idea which one it is. All help appreciated. |
I believe there is a diagram in the fuse box by the drivers side door
There should be.... But there isn't. I decided to just remove the fuses 1 by 1 till I found the one that had blown.
Thanks anyway |
damn. haha how long did that take? btw i think it was the 15 amp right in the middle.
and i will try to find my scanner and scan it online and hopefully stickey that ****. lol |
Anyone knows where the dome light fuse might be? For some reason mine is staying dim lately even when i manually turn it off and even when i turn my car off...
Where is the fuse box in an 2007 clk63?
Found it
2 Attachment(s)
There are three fuse panels - front SAM (left side, under the hood), cabin (driver's side dash), and rear SAM (in the trunk). There is also a "pre-fuse" panel, which is located on the passenger side, in front of the battery, under the positive jump terminal. These are hish-amp fuses fed directly from the battery. I have all the diagrams here:
http://benzbits.com/w203/fuses.html |
My alarm is going off for no apparent reason so I have been leaving it unlocked. However today I went out in it, parked and got out. The alarm went off and would not turn off. I had to drive home with the alarm going off continually.
Your ATA horn is likely defective. For now, just unplug it. It's located behind the passenger front wheel, behind the fender shroud.
All fuses are Identified, BUT the relays are not identified, Help!
Where can I find the relay identification, and locations. 2007 CLK 350. Tom. |
See my link above. It has the relays and fuses. It's for the W203, but it's 99% the same for the W209.
Can someone tell me what fuse 65 is for? I don't see it on the list posted by JustonArnold. It's a big fuse (45 amp). It's there in my fuse box but I can't find any list that tells me what it's for.
Originally Posted by Hermosahills2
(Post 6955648)
Originally Posted by Rudeney
(Post 6645598)
Here's the W209 diagram:
http://benzbits.com/w209/CabinFusePanel.pdf It has the same fuse numbers, but a few different assignments. |
(Post 7423192)
http://benzbits.com/w209/CabinFusePanel.pdf It has the same fuse numbers, but a few different assignments. There is 1 that is a 75amp and is blown, does this control more than 1 device? I don't a fuse that high, I guess I need to order some. |
Originally Posted by MPDano
(Post 7423241)
Thanks for that. I now see that there are a few spots that don't even have a plug so if you count that as a slot, it matches. 26 is for the sound system but it's good. There are a few posts that say the trunk panel has the fuse for the sound amp. All mine look good as far as I know. Not sure if there are some missing. Really need a pic of someones W209 trunk panel.
(Post 7423192)
Lads, battery is dead and key wont open drivers door on my 2004 CLK Cabriolet. It will open the boot. Which fuse can i remove to send power back to the battery to be able to remote open the door lock
