Shifter Base Plate
Shifter Base Plate
The base plate of my shifter comes off when I shift. I found that there are 4 clips underneath the base plate and one is broken.
This is the piece with the C/S switch. I like to search for this part but I don't know the proper for it. Please help.
Usually called
the shifter surround.If it is the part that surrounds the shifter and has the switches located in it.
From the top, it looks OK. The C/S switch and the surrounding chrome are all OK.
But when I shift, this plate will move up. I checked and there are 4 clips which secure it in place. One of these clips is broken, the one furthest from the radio.
I think it's one single piece.
Yes, it is indeed called the Shifter Surround.
It is the plate which supports the shifter. It has the C/S switch and also the display of P, R, N, D.
No wood inside the plate. It's black, with chrome around it.
The defective part is the chrome trim. Because one of the clip is broken (the one near the armrest), the plate lifts when I shift.
BTW. Dynomite05: We have the same car, 2004_CLK320,
04 CLK 320 > CLK32K
The switch should be fine, the cables have a bit of slack on them. I will take some pics tomorrow of my center console. The only thing I have on it is the C/S switch and chrome trim...lol
Better than I thought. Had some problems to remove the lock on the shifter, it was stuck a bit. Also, to lift the shifter snob was not easy, I had to pull hard and I was concerned that I would break it.
I must say that these MB parts were made very well.
