Need Help! Stereo Install w/ HK for CLK55 (w209)
Old Nov 27, 2010 | 10:03 PM
benamg22's Avatar
CLK55
Well, I'm a newbie (I also posted this under the CLK AMG forum, but decided I might get more attention in the CLK (w209) forum). I have been searching the forums in an effort to find information that will help me install a new sound system using my stock HU. I have a 2005 CLK55 (w209) with the Harmon Kardon sound system. My plans are to tap into the existing speaker wires connected to the HK amp in an effort to install a hi/lo converter on the output side of the amp. I understand from reading various posts that its possible to tie in on the output side in an effort to avoid messing with the fiber optic connections and to maintain all existing controls (steering wheel etc.). I'm hoping someone can give me some tips on first locating the HK amp and second any wiring diagrams or information to know which wire connects to which speaker. Also, any information as to the best location to tie into the existing speaker wires going to the sub will help. I haven't decided to do a full replacement or just the sub to start. If I do decide to install an entirely new system I'm wondering if anyone has tied into the existing speaker wires going to the doors from the new amps (connected to new speakers in the door obviously). I've found a lot about Bose systems, but very little about HK. I really appreciate any help any of you can provide to help with this install. Best I can tell I can do a complete speaker overhaul for about a third of the cost that's been quoted by a professional installer. I've got some experience with car audio from back in the day, so I'm hopeful this project will be like riding a bike. Thanks again.
Old Nov 28, 2010 | 12:32 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
Amp is in the trunk, right side behind the carpeting. If the amp you buy does not have high level inputs, you'll have to buy a line level converter. Keep in mind that if you are going to change all the speakers out - the system is 2ohm, not 4ohm.
Old Nov 28, 2010 | 09:48 PM
benamg22's Avatar
CLK55
Thanks a lot Kevwood. I assume that if I install 2 ohm speakers in the door (I am looking at Infinity compoents) I should be okay. Any tips on picking the correct subs?
Old Nov 29, 2010 | 07:54 AM
Kevwood's Avatar
Highly doubt you'll find 2ohm speakers mate, if you install 4ohm you are going to lose volume in the factory system. Same principle as installing home audio 8ohm speakers into a standard 4ohm car system.
As for the subs, what is your enclosure plan?
Old Nov 29, 2010 | 09:49 PM
benamg22's Avatar
CLK55
I found some Infinity 2 ohm components and 6.5 mid/hi for the doors. I'm going to use a JL 320 4 way amp for these and install the crossover somewhere in the door. I'll use the existing factory speaker wires to get to the door and tie the crossover in there. As for the sub, I'm planning to use a JL 10w3v3-2 2 ohm with JL 500 mono amp. All this will be run through a JBL MS-8 Sound Processor. I'm planning to build a custom port through the rear armrest (cover the plastic insert with material matching the seat and insert a 3" port). The enclosure has to be 1.25 cubic feet, so with the width of the trunk I shouldnt' have any problem. You know there are two elevations in the trunk, so I'll probably build something not exactly square (almost like two separate boxes), assuming I can use the upper deck and still get the depth to top mount the speaker. I am going to use a flexible hose/pipe to run the port from the enclosure to my port in the armrest. Of course figuring all this out is the easy part. I've purchased a "factory service" dvd from ebay hoping it will contain wiring diagrams and instructions to remove panels, but we'll see if it is everything the seller promised. My two biggest concerns are getting power to the battery (through the firewall) and figuring out which speaker wires coming from the HK amp are for which speakers. Have you ever seen a wiring diagram or do you know if these are marked? Let me know what you think.
Old Nov 30, 2010 | 03:05 AM
Kevwood's Avatar
Nice find on the 2ohm speakers, I never thought of Infinity but now that you mention it, they have always had a very strong aftermarket for morphing into a factory system.
Sound like you've got it all figured out equipment wise and a good plan for the install. There is a wire guide and other info floating around on this and other boards.
This is an excellent thread;
https://mbworld.org/forums/clk-class...o-upgrade.html
Another fantastic thread;
http://www.benzworld.org/forums/audi...an-becker.html
Basic wire guide (post #7);
https://mbworld.org/forums/clk-class...g-diagram.html
All you need to do in return for this info is to keep us up to date and post pictures
Good luck matey!
Old Nov 30, 2010 | 12:20 PM
apb's Avatar
apb
08 S550, 10 GLK350, 05 Clk500
you may try to only upgrade the amp first. The stock speakers are high quality (unlike the Bose ones).
Old Nov 30, 2010 | 10:54 PM
benamg22's Avatar
CLK55
Kevwood - Thanks for the great links. I'd seen two of these, but the third with the amp wiring pics I had not. It will help! I'm planning on doing the install between Christmas and New Years, so be patient on my pics!
As for using the stock speakers, I've thought about at least trying them first with the upgraded amp. I've read people think these are pretty good. Worst case I can replace them after the fact since I am going to install a new 4 channel amp.
Big question....anyone know which wire is the "remote in" to the factory amp - surely it is not a fiber optic connection like the speakers from the HU, but I'd love some verification on that too? I am not going to install a new HU, so I don't want to have to run to the cigarette lighter, and the JBL MS-8 says you must cut the factory amp remote in, run it to the remote in on the JBL, then run the remote out from the JBL back to the factory amp. Don't know how it would know, but hate to ignore the instructions.
Thanks. You guys have been very helpful.
Old Dec 1, 2010 | 02:04 AM
Kevwood's Avatar
If you are going to use the factory speakers you need to keep in mind that you'll be placing a 2ohm load on the amp, other than sub amps 99% are 4ohm stable for high pass. You'll be working the amp harder and building up more heat than you would at 4ohm. Change the speakers out if you're going to be introducing a new amp.
Old Dec 2, 2010 | 09:39 PM
benamg22's Avatar
CLK55
Okay, so I took out all my trunk panels tonight and I can't find the amp. After searching I can't find any pics to help me locate the amp in my trunk. Everyone says it's on the passenger side behind the panels, but I just can't see it. I do see what appears to be all the speaker wiring, but before I start cutting I want to confirm these are truly for the speakers. Any advice? Thanks!
Old Dec 3, 2010 | 10:24 AM
moondust's Avatar
2004 CLK 240
Do these drawings help? But they are for the coupe only.
If you have a cabriolet, the amplifier unit is located elsewhere (on another drawing).
Your vehicle type is important for trunk-mounted items that are often re-located in the cabrio version. You should always state the vehicle details.
File Type: pdf
File Type: pdf
Old Dec 3, 2010 | 12:19 PM
benamg22's Avatar
CLK55
Great pics m/dust. Thanks. Mine is the cabriolet version if you have those pictures, I'd sure appreciate that. You've already been very helpful. Thanks!
Old Dec 3, 2010 | 01:20 PM
moondust's Avatar
2004 CLK 240
OK, here's the drawing for the cabriolet version of CLK. I can now understand why you had difficulty finding the location the amplifier, as from the drawing I can see that it is behind several other items.
Refer to drawing items 2, 3, and 4 for access information. Have a think about proceeding further, as you might need more detailed information from the specified drawings.
I have edited my earlier post, as I now realize some info there was incorrect.
File Type: pdf
Old Dec 3, 2010 | 01:45 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
Wait a minute.......I recognize those WIS .pdf files.....Is that Keyhole from benzworld?
Old Dec 3, 2010 | 02:55 PM
moondust's Avatar
2004 CLK 240
Guilty - as charged....
Old Dec 3, 2010 | 02:56 PM
benamg22's Avatar
CLK55
This is perfect. Not only will I be able to find and disconnect the factory amp, but I don't feel so stupid about not finding it on the right side of the trunk well. Thanks again.
Old Dec 3, 2010 | 02:59 PM
benamg22's Avatar
CLK55
While you guys are on, any clue on the switched power on the amp or suggestions for switched power in the trunk. Thanks again....big big help.
Old Dec 3, 2010 | 03:07 PM
dynomite05's Avatar
04 CLK 320 > CLK32K
I would say welcome, but I see you have been a member for a while. You should definitely be more active over here. You are a very useful resource.
Old Dec 3, 2010 | 04:04 PM
Clkboi's Avatar
CLS550 4Matic
Keyhole posts here really? Lol he is the only member at benzworld who gives useful guides for the w209. I always thought you were the admin.
i am glad you are here too
Btw who owns this forum?
Old Dec 3, 2010 | 06:28 PM
moondust's Avatar
2004 CLK 240
Depends how much power you want to pull. What do you have in mind?
If not much, you might consider tapping into the cableform for +12v supply to the Amp, which is fused via f26 at 25A.
If you look at the circuit diagram I provided, on the extreme left hand side, you will see the supply line on a RED/VIOLET wire that goes to pin 26 on the amp.
Also consider using spare fuses on the fusebox in the trunk (l/h side). My fuse map shows f5 and f11 are spare on my CLK, so you could wire your new circuit into either of those.
Regarding the circuit diagram, note from the legend that where different, cabrio/coupe items are shown in a box with chained line around, eg - - - -
a) U23 = cabriolet
b) U611 = coupe
Old Dec 3, 2010 | 09:27 PM
benamg22's Avatar
CLK55
Moondust - I pulled the right side trunk liner and found the amp easily using your diagram tonight....very helpful and much appreciated. Sadly, the wires are tucked pretty snug behind the hydraulic pump for the the soft top, which is going to make it tricky trying to cut and splice into the speaker wires. It will take time and patience as I do not intend to pull the hydraulics out (nor the fuse panel). I think if I can loosen the amp I can get the harness out and get just enough slack to make it doable.
As for the 12v, all I need is a remote wire for the sound processor (which will then feed the new amps). Do you know or can you tell from the diagram if F34 at 26 is switched or contant power? The JBL MS-8 unit I'm considering wants you to take the 12v in from the factory amp and run its remote out back to the factory amp. However, upon my research I think it will take an alternative remote in and still get the job done. My other option is an Audiocontrol DQL, which has a remote turn on using the high level input from the amp. It then converts the signal to a 12v to trigger the amps. My preference is really the JBL just because I would be linking a Harman sound processor to the factory Harman system. Don't know if it makes a difference, but can't hurt. More to come.
Last question (for now), can I assume the other 2-pin connector (labeled U1/U2) is the fiber optic coming into the amp?
Keep the advice coming if you have any tips.
Old Dec 4, 2010 | 06:00 AM
moondust's Avatar
2004 CLK 240
Yes. Items 2, 3, 4 detail how you can get access by 'loosening' other items but not actually removing them.
I took a look at other circuit diagrams. The +12v line I referred to is NOT SWITCHED. The route is as follows.
Battery > F32 (prefuse box) f1 (125A) > F34 (fusebox in cockpit driver's side) f26 (25A). So this supply is live with the ignition off.
However, the circuits inside A2/13 might not be energised until the 'wake-up' signal is received via the MOST fiber-optic highway on switch-on.
Not sure what 2 pin connector you refer to here, but the fiber-optic MOST connectors to A2/13 are shown on the far right of the diagram. This bus is daisy-chained between units, and p1 is IN, p2 is OUT.
Old Dec 5, 2010 | 12:08 AM
benamg22's Avatar
CLK55
Thanks again Moondust. I think I'll try the loosening to get the amp down far enough to pull the connector, as well as the surrounding components. The 2-pin I was referring to is the MOST connector, which is what I wanted to confirm. You've been a big help. If I run into any issues I'll probably message you. I really appreciate it!
Old Dec 5, 2010 | 01:33 AM
Clkboi's Avatar
CLS550 4Matic
Not sure if this will be any help to you but this guy is a real genius and has done so much to his CLK
http://forum.evotechnik.net/showthread.php?t=21258
Old Jan 29, 2011 | 12:08 AM
M-bENZ's Avatar
Corrolla
Sorry for bring back the old thread but i cant tell which wires are for our stock subwoofer from the amp diagram ? is it H4/29 ? and what colors is that ?
Andy
