Finally, CLK550 Dyno!
Rating: Thread Rating: 10 votes, 5.00 average.
Old Mar 28, 2011 | 06:44 AM
elijah's Avatar
Euro Cars Only
The guy was banned more than once and was very proud of it to!
True his car is putting down some impressive numbers but the attitude that came along with all the bragging was just over the top and many people here disliked him for that. He'll be back
Old Mar 28, 2011 | 11:24 AM
Jamesbbh's Avatar
2006 Facelift CLK500 Cab-
This thread is starting to make me mad for some reason. Nothing against bad black at all, I think it's just all of this banter going on.
Old Mar 28, 2011 | 12:48 PM
fivepointfive's Avatar
CLK320 AMG
Originally Posted by Klinh
That does not mean your products 100% problem free. Let wait until you do an inspection on the old pulley before you blame the shop too. If the keyway is improperly line up during installation, you will definitely see scrap mark on the pulley even with a slight mis-alignment. The worse case I seen, the keyway got push back into th engine. 10 years ago I seen the same exact problem after I inspected 2 car with ASP pullies. One were due to out of balances and the other were due to the base of the pulley wasn't smooth enough cause rubbing to the seal.
Thats some very interesting info i will forward it to another forum for bad black to read.
Old Mar 28, 2011 | 12:54 PM
betrezra's Avatar
C63 507 AMG DA Car #19
Why are we talking about a banned person anymore.
time to move on
Old Mar 28, 2011 | 12:59 PM
chrislis's Avatar
2005 CLK500
time to move on
/thread.
Old Mar 28, 2011 | 03:10 PM
Klinh's Avatar
C63s Cabriolet, BMW M4, Civic
time to move on
Don't take this the wrong way but if you're not intersted, don't read or response to the thread. Some of us are talking about his problem not him.
Old Mar 28, 2011 | 07:34 PM
  #32
sleepyheadzzz's Avatar
2000 Volvo S40, 2006 Hummer H3, 2008 CLK550
i want some kfc
Old Mar 28, 2011 | 10:53 PM
  #33
AMS Performance's Avatar
Former Vendor of MBWorld
AMG
The customer has contacted us and is now saying the shops story is not adding up. Before they installed it they were hesitant and unsure exactly how to install it (not exactly a sign of confidence). Then he further stated that the shop did not stabilize the crank at the transmission flywheel like he was supposed to (this is the correct way of installing it). Instead, the pulley tool method was used but it is not the approved was of installing the AMS pulley.
Its becoming clear what the issue is, either way hopefully the keyway is still in decent shape. It is possible to install the pulley without the keyway, the keyway is purely to line up the timing marks with the crank orientation, but is not absolutely essential (it is recommended).
Thanks again,
~AMS~
Old Mar 29, 2011 | 12:07 AM
  #34
Klinh's Avatar
Thanks again,
~AMS~
Removal and installation pulley doesn't really require locking up the flywheel if you use the impact gun. But you definitely have to lock up the flywheel when time to torques down the bolt around 125-150 lbs-ft (depending on model). If I were you, have the customer take a picture of the pulley keyway groove to see if there's any sign of damages and problem solve.
Old Mar 29, 2011 | 12:08 AM
  #35
Newjd2's Avatar
2012 CLS 550 Launch Edition, 2004 CLK 500, 2004 Honda Civic
Great to hear as I'm about to purchase a pulley...just doing my research...
Either way wish badblack the best....
Angelo
Old Mar 29, 2011 | 10:07 PM
  #36
user 76208202's Avatar
CLK550
What are his mods? Exhaust, pulley and ECU?
Old Mar 29, 2011 | 11:48 PM
  #37
CLK320 AMG
Resonator Delete, Pulley, ECU. Looks like if his pulley was not wobbling and there was no oil leak he would be in 385 before wather correction.
Old Mar 30, 2011 | 02:51 AM
  #38
CLK550
still don't understand why someone would get a dyno when the pulley is wobbling and oil is leaking? i'm sure things were fine..no one in their right mind would push a car with a wobbling pulley. looks like these are the max #'s he could have gotten with those parts.
Old Mar 30, 2011 | 10:00 AM
  #39
CLK320 AMG
hes been banned many times so i don't think hes in the right mind lol.
Anyways those are very big numbers.
Old Mar 30, 2011 | 10:33 AM
  #40
grmnpwrd's Avatar
CLK 500
these numbers are on a mustang dyno...which is a known to read low compared to a dynojet which is more accurate
Old Mar 30, 2011 | 04:43 PM
  #41
CLK320 AMG
+10
Old Mar 30, 2011 | 06:04 PM
  #42
AMG
I agree, the car never should have been dynoed with oil leaking and wobbly pulley, the dyno operator should have known better.
Either way, AMS is here to back up the customer with our full support. If they need a new pulley a new one will be provided free of charge as a part of our AMS Lifetime Warranty.
Thx,
AMS
Old Mar 30, 2011 | 06:08 PM
  #43
dynomite05's Avatar
04 CLK 320 > CLK32K
Thx,
AMS
The car is in the shop as we speak. As soon as we get an update, I'm sure he will pass it on to you. Thanks for the help.
Old Mar 30, 2011 | 06:24 PM
  #44
Moedy's Avatar
'05 CLK55, '04 CLK320
Great numbers but I dont believe you can achieve over a 50whp gain with a tune, resonator delete and pulley on a n/a vehicle. This has to be some kind of mistake. Put it on a dyno dynamics or bring it to the track
Old Mar 30, 2011 | 11:54 PM
  #45
CLK320 AMG
bad blacks clk ran against a 335i that did 12.5 at the track, and blacks car walked it pretty easy. So i don't see how there is a mistake.
Old Mar 31, 2011 | 12:50 AM
  #46
kbahl21's Avatar
CLK & GL
nobody here has stock hp # on the clk550,do they??
Old Mar 31, 2011 | 01:07 AM
  #47
Klinh's Avatar
I find it very very hard to believe that black's car ran a 12.5 with just minor mods because the AMG E55 Kompressor stock ran 12.5. My friend's C55 with Kleemann SC ran an 12.4. Video........anywhere?
Here's the info I got from Car and Driver magazine.....
"Of course, the telltale sign that really matters resides under the hood in the form of AMG's hand-built 5.4-liter, supercharged-and-intercooled 24-valve V-8, which puts out a Jack LaLanne-healthy 469 horsepower and 516 pound-feet of torque. Teamed with a heavy-duty AMG five-speed automatic, the blown V-8 produces staggering results: 0 to 60 in 4.1 seconds; the quarter-mile in 12.5 at 114 mph; and 0 to 150 in 24 flat. The comparisons at the start of this story show what kind of sports cars this wagon stays door to door with. "Mommy, race that Ferrari!""
http://www.caranddriver.com/reviews/...take_road_test
Old Mar 31, 2011 | 02:22 AM
  #48
Klinh's Avatar
Very misleading depending how he raced the 335i. Let just assumed that the 335i did ran a 12.5s 1/4. But if black raced him with rolling start, or from 40 mph, or from 80 mph...etc. like most of his video we saw, it not an accure results. You really have to race from 0 mph to top speed for a real result. I remember 10 years ago I raced mine Slk230 ASP pulley kit with mine friend e320. He beat me every single rolling start no matter at 30, 40, 50 mph. Then we finally took it up to 145 mph. I slowly past him at 130 mph then 3 cars lenghts at 145 mph. It was his torques that alway make me play catch up.
Old Mar 31, 2011 | 02:32 AM
  #49
kbahl21's Avatar
CLK & GL
+1
Old Mar 31, 2011 | 03:12 AM
  #50
dr_npz's Avatar
09C63AMG, 03E320
Jeez, this crap about straight line racing. Take it to a real racetrack and you will see the real results. I'll get smoked by couple of seconds by the 335, handling is incompareble to 550. Everyone can step on the gas and do burnouts.
And yes, i say those numbers are really impressive, but who the hell cares if it is faster than that or that, just enjoy what you have by yourself.
Everything about straight line and drag racing, somehow i don't get it. Maybe its just the european point of view, where suspension and handling is far more important than power in straight line.
You have already rated this thread Rating: Thread Rating: 10 votes, 5.00 average.
