CLK AMG Black Series paddle shifter retro-fit
Old Feb 29, 2012 | 10:43 AM
  #76
M-bENZ's Avatar
Corrolla
OK just want to make this clear....all the infor that Carlos posted above those are just for the car that has the phase 1 only right ? People with the car from 05 and up dont have to do this like mine and Kev car ...right Kev ?
Old Feb 29, 2012 | 10:52 AM
  #77
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
If you already have dual phase shift buttons, you just do as I did - that's it that's all.
If you have a CLK55 with single phase shift buttons, you need to either swap electronics within the paddles or buy the new adapter module available from DCT.
if you don't have any shift buttons (like Carlos & Mike), you have to add all the hardware and have them coded in.
Old Feb 29, 2012 | 11:02 AM
  #78
M-bENZ's Avatar
Corrolla
Got it.
Old Feb 29, 2012 | 10:52 PM
  #79
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Some Info on Programming for code 428 (from some UK Mercedes forums)
When the car is on the diagnostic there is a function called RETROFITS in the same screen as the short test. It is the 4th option in most cases.
Using his dealer password he will enter this option and add code 428 to the car and hit enter.
After 20 min or so he will then go to the Transmission controller and perform SCN coding.
There is a way to do this manually with experienced user but that information is specific to a car chassis and not generic for all cars. So in that sense there is no universal "hack" for this. The dealer is the best option.
The othe way is for the dealer to email your request to a "Level 4" VeDoc user who can modify your Datacard which is held centrally at Mercedes. Then after this modification some time later you can perform SCN on the transmission controller.
They should not laugh. It is very easy for them to do it - if they want to.
Old Feb 29, 2012 | 11:36 PM
  #80
Kevwood's Avatar
Interesting find there Carlos.
Old Nov 28, 2012 | 11:25 AM
  #81
LOB's Avatar
LOB
CLK 270CDi
Could someone tell me the price of A1694640918 replaced by A1694640518 replaced by A1694641018 in USA?
Best regards
Old Nov 28, 2012 | 12:18 PM
  #82
latemodel21's Avatar
2003 SL55 / 2002 SLK32
Best regards
$261 w/free shipping (in the US) from oediscount
http://www.oediscountparts.com/parts...&siteid=215242
Chris
Old Dec 12, 2012 | 10:42 AM
  #83
LOB's Avatar
LOB
CLK 270CDi
Chris
Thank you very much Chris!
Old May 2, 2014 | 09:27 AM
  #84
TUNINGSHOP's Avatar
W230 350 W203 C200
Originally Posted by 2MCHCAR
Okay Guys, we can solve this Da Vinci Code for Code 428 (Paddle Shift Option). Here is what we know so far:
Hardware Components Needed
  • CLK320, CLK500, CLK55 (2003-2004) - Contact Spiral (#120 on the diagram below. With Steering Angle Sensor and Code 428) A1694641018 or A2034640118 (depending on build date - Footnote From Chassis: F 088109 From Date: 14/01/2004 Except model year: 804) My 2004 CLK500 has A2034640118.
  • Paddle Shifters (#11 on the diagram below) A2308218751 (Older Style - Smaller and Black in color) or A1712670046 (CLK63 Style - Bigger and Silver)
  • Control Unit/Steering Wheel Switch - (#12 on the diagram below, code 428) - A0365457032
  • Other Hardware needed????
Wiring (from other internet sources)
The WIS circuit for the CLK55 AMG shows Steering wheel gear shifter MINUS switch (S110/1) and Steering wheel gear shifter PLUS switch (S111/1) routed first to Clock Spring contact (A45).
From there, the wires pass to Steering Control module (N80) and then to Electronic Selector Lever control module. (N15/5) One wire is taken to chassis (W28/1). The other wire goes via terminal block X35/1 to Connector 1, pin 4 on N15/5.
Software Components Needed (Info I found from other internet forums)
Procedure to activate the paddles:
a) Change the wheel
b) Add code 428 in the VeDOK database and
c) SCN Code the car
(From other forum)
I took my car in for service to dealer and told them that the shifters stopped working and I needed regular service / oil change. They looked up the VIN # and it shows the car coming from factory with paddle shifters, they then ran a transmission diagnostics test and found that the shifting points had been deactivated. They did a factory default parameter down load and shifters work. Total cost for this was $68.00 for the transmission diagnostic test and default down load.
So it looks like only the dealer can version code vs. someone who has STAR with developer mode.
HAVE YOU MANAGE TO MAKE IT PLAY ?
Old May 5, 2014 | 03:26 PM
  #85
Rogue-CLK's Avatar
2016 C300 4Matic
This wouldn't work on an 03 clk 500 would it? 😢
Old May 6, 2014 | 02:20 AM
  #86
TUNINGSHOP's Avatar
W230 350 W203 C200
WHY NOT ?
