Ignition fuse keeps on blowing
Old Jun 28, 2011 | 07:29 PM
Daygoskater's Avatar
03 CLK320
so for the pass two days i had to replace my ignition fuse. the first day is when i was going into a shell gas station. when i was getting on the drive way my whole car shuts off. and after troubleshooting the problem it was the ignition fuse that blew. the 20 watt fuse inside the car. Then today when i went over a speed bump the car shuts off again for the same reason. Im really confused what could be causing the problem. it only happens when i go on a bump of some kind. has anyone experience this problem and was able to fix it or any suggestion why it would be blowing. thanks you!
Old Jun 28, 2011 | 10:42 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
Sounds like a dead short somewhere. Like a loose, or nicked wire grounding itself.
Old Sep 2, 2018 | 09:43 AM
Fatman Williams's Avatar
S55 /cl55
