Does my 2006 CLK Cab have an emergency trunk release?
Old Apr 23, 2012 | 04:53 PM
fast911ray's Avatar
1999 C280
..actually it's a customer's car. It seems he locked the ignition key in the trunk, along with a small safe and three handguns! Don't ask...!!! Anyway, he does not have a trunk key and is planning to sell the car. Of course he'd like to retreive the items mentioned first, as well as the ignition key. Any ideas?
Old Apr 23, 2012 | 07:18 PM
Mka77's Avatar
06 CLK350 -SOLD! 2010 Cadillac SRX Premium Turbo
It has one, but it's inside the trunk. No help for your situation. From the back seat is there any access to the trunk?
Old Apr 23, 2012 | 09:31 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I assume the vehicle is locked, otherwise he could just unlock the doors and then open the trunk with the handle, or press the trunk release button on the driver's door. I'd call "Pop-a-Lock" or someone similar to open the vehicle.
Old Apr 23, 2012 | 11:27 PM
Yidney's Avatar
2008 CLK550 Cab
I thought you couldn't lock your keys in the trunk. No? I know I can't lock mine in the car. The doors will not lock if the key is inside the perimeter of the car and the engine off. I thought that applied to the trunk also. Is that a keyless go feature?
Old Apr 24, 2012 | 10:04 AM
KENNY94945's Avatar
Best is to get inside the vehicle and press the trunk release button.
(Emergency is the metal key or as above the release inside the truck.)
I do not think there is access to the trunk if the rear seats are removed...but then again you need to get inside the vehicle.
Old Apr 24, 2012 | 09:07 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's only the case if you have KeylessGo where there are sensors to detect the key. Without KeylessGo, you can very easily lock your key in the trunk.
FYI, if you have to use the metal blade key to unlock the trunk from the outside, you have to turn the key and then pull the handle. I forgot about this on my C240 and thought the lock was broken!
Old Apr 25, 2012 | 04:59 PM
lars's Avatar
05 CLK 500 cab
Yup. I wondered how when I read this thread so I'd know what not to do. Open trunk, climb out, lock car, put key in coat pocket, take briefcase out of trunk, remove coat and place safely in trunk....
