Please check my VIN for Balance shaft issue?
Old Jan 16, 2016 | 07:43 AM
  #1251
edm163's Avatar
'06 Mercedes R350; '07 GL450
Contact me for any balance shaft repair in the NYC / NJ area. Will beat any price and job done in 3 days. All work GUARANTEED!
Old Jan 17, 2016 | 03:10 PM
  #1252
Ptrigg17's Avatar
2009 CLK550 convertible, 2012 ,,E550 Cabrio, 2012 Audi Q5
Hello everyone I am new to this forum, I have placed a deposit on a 2007 CLK 550 convertible with 74k and then found this forum. After doing some searching I came across this issue and also the 7 speed transmission issue. If someone could help me determine if I need to be concerned about either of these issues I would really appreciate it . My Vin. WDBTK72F97T085431
Old Jan 17, 2016 | 10:56 PM
  #1253
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That has M273 engine #135760 - it's beyond the range for "balance shaft" failure, but it may still have transmission issues withe the conductor plate. There's no serial number range for that, but generally, many cars before MY2008 were more prone to failure.
Old Jan 23, 2016 | 10:38 PM
  #1254
piepants's Avatar
CLK 500
Engine Serial Number
Hi,
I am thinking about purchasing a CLK 500 with VIN WDBTK75JX6F171649. Can someone check the VIN to see if this is within the range of vehicles affected (or direct me to a site that can determine the serial number)? Judging from the class action lawsuit, I believe this car will fall out of the 10-year range to have the repair completed complimentary.
Thanks!
Old Jan 24, 2016 | 09:35 PM
  #1255
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by piepants
Hi,
Thanks!
M113 engine - no balance shaft issues there.
Old Jan 24, 2016 | 10:09 PM
  #1256
piepants's Avatar
CLK 500
Thanks for the reply Rodney!
Old Feb 1, 2016 | 11:24 PM
  #1257
Dgee's Avatar
ML350
Rodney, would you be so kind as to check out the vin on a vehicle I'm looking to purchase?
VIN: 4JGBB86E26A127447
2006 ML350
It's got 168k on it so logically thinking it would of failed by now I would think. The current owner has never had a problem with check lights and has had it for about 3 years and bought it right around 130k
I appreciate any advice you have and thank you for checking out the vin!
Old Feb 2, 2016 | 11:16 PM
  #1258
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No need to check the VIN - ALL MY2006 vehicles with the M272 (xx230, xx280 xx300, xx350) of M273 (xx450, xx550) engines will be "in the range". Only MY2007's need checking by VIN.
Some people suggest that the higher the mileage, the less likely premature failure will occur. Others suggest that "all" of these engines have defective parts, it's just a matter of "how early" they fail. Anything before 300K miles is "early" since that's the expected lifespan of a timing chain and its sprockets.
Old Feb 23, 2016 | 06:59 PM
  #1259
Foondar's Avatar
2006 R350
Thank you very much Rodney, can you please check my VIN:
4JGCB65E26A003558
Old Feb 23, 2016 | 11:08 PM
  #1260
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's a MY2006 - all MY2006's will have an engine in the range for potential balance shaft failure. Onyl MY2007 is split and needs checking by VIN/engine serial #.
Old Feb 26, 2016 | 10:23 PM
  #1261
MBZAMG7's Avatar
BMW 840ci
2009 CLK550
Hi Rudeney,
I am planning on buying a CLK550. Would like to know if 2009 model also had the same balance shaft and transmission issues as the 2007 and 2008.
Is there anything in particular that goes wrong with the 2009 CLK550 that I need to watch out for ?
Thanks in advance
Old Feb 27, 2016 | 11:05 AM
  #1262
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
No the balance shaft issue was discovered and resolved during the MY2007 build, so MY2008 and later are all fine. By MY2009, the last year for the W209, most all the bugs were worked out and owners report few problems, really none of them major. Just follow the MBZ published maintenance schedules, and add in a transmission fluid and filter change (with torque converter drain) every 40K miles (MBZ only calls for one at 39K).
Old Feb 27, 2016 | 12:06 PM
  #1263
MBZAMG7's Avatar
BMW 840ci
Old Mar 23, 2016 | 11:14 PM
  #1264
BadaBing7's Avatar
'06 C230
ML-350
Rudeney,
Sorry I do not know where else to look but could you check
4jgbb86e77a251554?
Thanks!
Old Mar 24, 2016 | 09:46 PM
  #1265
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
M272 #600663 - it's beyond the problem range.
Old Apr 12, 2016 | 11:15 AM
  #1266
MBZAMG7's Avatar
BMW 840ci
VIN check
Hi
Can you check the following VIN number for me. If the car is not in the range for balance shaft issue could it still have the defective camshaft solenoids issue
WDDGF56X28F045583
Thanks in advance
Old Apr 12, 2016 | 10:58 PM
  #1267
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
no need to check - that's a MY2008. Balance shaft only needs to be checked for MY2007's - before that, all M272/M273 engines are affected. After that, none are.
Old Apr 25, 2016 | 05:52 PM
  #1268
M-bENZ's Avatar
Corrolla
Hi Rudeney ,
Could you please check this VIN too ? I'm thinking to buy this C230 next week...
WDBRF52H86F748876
Thanks!
Old Apr 25, 2016 | 09:11 PM
  #1269
Rainers's Avatar
Can someone check vin# WDBUF87X88B206859
I got the p0025 code last night
Thank you
Old Apr 25, 2016 | 09:59 PM
  #1270
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Originally Posted by M-bENZ
Hi Rudeney ,
WDBRF52H86F748876
Thanks!
That's a MY2006 - all MY2006's are "in the range". We only need to check MY2007.
Old Apr 25, 2016 | 10:02 PM
  #1271
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Thank you
MY2008 is no worries for balance shaft issues - that was resolved halfway through MY2007. P0025 = DTC 0064 which is a symptom of "Scenario 2". You just need to replace the camshaft adjuster solenoids (a.k.a. cam magnets). Parts are about $100 for all four and it's a 2-4 hour DIY job, if you are so inclined.
Old Apr 26, 2016 | 08:43 AM
  #1272
Rainers's Avatar
Hi Rodney,
Thank you for the quick reply, I was worried even though I have a MY2008 because the delivery date was 7/16/2007.
Delivery date: 16 07 2007
Engine no.:
272972 30 675687
WDBUF87X88B206859
Old Apr 26, 2016 | 03:09 PM
  #1273
M-bENZ's Avatar
Corrolla
Rudeney , thank you for the reply and does it mean it's a no go ? Run away from this car ? I have to admit we like this car
Old Apr 26, 2016 | 08:46 PM
  #1274
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Hi Rodney,
Engine no.:
272972 30 675687
WDBUF87X88B206859
Delivery date means nothing - it's about the model year in this case. And as you can see, your engine is well beyond the problem range (it ended with 272xxx 30 468993.
Old Apr 26, 2016 | 08:47 PM
  #1275
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Personally, with my luck, I'd pass and go look for one out of the range. There are so many good cars out there beyond the range, why roll the dice?
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
