Please check my VIN for Balance shaft issue?
Rating: Thread Rating: 8 votes, 5.00 average.
Old 06-19-2018, 10:02 PM
  #1526
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by Stoimen Stoev
WDD2163711A014302
Can you please check this vin?
Thank you!
M273 engine #206632 - well beyond the problem range.
Old 06-26-2018, 07:26 AM
  #1527
hudge's Avatar
clk280
2006 SL350
VIN WDB2304561F1311150
Motor 272966 30 531083
Transmission 722906 00 992754
Im looking at this 2006 SL SL350 here in Spain. Engine (balance sgaft) or transmission issues?
Many Thanks
Hudge
Old 06-26-2018, 04:00 PM
  #1528
xsever's Avatar
2012 C300 4MATIC Sport
Many Thanks
Hudge
For the balance shaft, the affected engines are up to 30 468993 so the engine on this car is clear of that, but the 722.9 transmission suffered from teething problems until 2008. I can't remember fully but the problems were related to the conductor plate and the fluid pump and the transmission is electronically-complicated enough that it requires the dealer or someone with SCN-coding to reprogram the TCU.
Old 07-26-2018, 02:25 PM
  #1529
SafeerQ's Avatar
2009 CLK550
Balance Shaft/Idler Gear
Hey All,
Just picked up my 2009 Calcite White CLK550 yesterday and I am loving it so far! I checked a VIN decoder online, but just wanted to be sure my 100k mile car doesn't have these issues. I figured this would be the best place to start!
VIN: WDBTJ72H99F269323
Thank you!
Old 07-27-2018, 08:45 AM
  #1530
Anker's Avatar
2009 CLK 350
If its a MY 2009 you are in the clear.
Old 08-11-2018, 10:08 PM
  #1531
A S
A S's Avatar
C-230 Sport Sedan
Hi Rudeney! Nice to e-meet you.. I'm thinking of buying a 2006 MB C230 Sport sedan with this VIN: WDBRF52H26A840269 this weekend. Kindly let me know if I'm in the affected range for balance shaft at your earliest convenience. Also-- if you have any insight about the longevity of this car henceforth viz engine , transmission, suspension, sensors, belts etc. kindly advise as I don't wish to get a lemon as you might understand. Look forward to your response--Thank you very much! Abs.
Old 08-13-2018, 11:24 PM
  #1532
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
MY2006 - so yes. Only MY2007 needs to be checked by VIN as the first half of production is in the range, last half is not. As for longevity, while the engine may be in the range for potential balance shaft failure, it is unlikely to fail. Still, do you feel lucky and want to roll those $5000 dice? Also, the early 722.9 7-speed transmissions are more problematic. Personally, if you want a W203 C-Class, I'd look for a My2005 C240 or C320.
Old 08-13-2018, 11:42 PM
  #1533
A S
A S's Avatar
C-230 Sport Sedan
Thank you very much for the response Rudeney.
Old 08-16-2018, 01:34 PM
  #1534
topgun129's Avatar
06 C350 4Matic
can you please check this VIN # - WDBUF56X38B258819 ? also does this have the 722.9 transmission that is known for having issues ?
Old 08-16-2018, 11:26 PM
  #1535
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
That's a MY2008, so no worries - it's beyond the range for potential balance shaft failure. And it does have the 722.9 transmission. Most of the transmission issues were resolved by then.
Old 09-13-2018, 02:20 AM
  #1536
tgrant56's Avatar
2008 s550 RWD
Hi rudeney here is my vin WDDNG71XX8A199737 not sure if im affected by just got my car diagnosed at a mercedes only indy and these codes came up p0012, p0022, p0015, p0025, what do you think it might be ?
Old 09-13-2018, 09:59 AM
  #1537
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
MY2008's liek yours will be beyond the balance shaft problem range. Those codes indicate bad camshaft solenoid adjusters (a.k.a. magnets). Replace all 4 of them. Parts are about $100 total, and it's a fairly simple job, though the radiator has to be drained so you can remove the oil cooler to access the left side.
Old 09-15-2018, 11:21 PM
  #1538
ZitoMD's Avatar
2005 CLK 500, 2010 Ford Fusion, 2012 Chevy Avalanche
Thanks in advance. Please check MY2005 CLK 500. VIN = WDBTK75G05T044669.
Old 09-16-2018, 10:20 AM
  #1539
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
No worries on the M113 engines.
Old 09-19-2018, 04:49 PM
  #1540
I belong JEA II's Avatar
F350
Can someone check this vin number also?
WDBTJ72H88F252219 2008 CLK550
engine has oil leaks not repaired also. I thought o remember a post where there were a range of engines with major problems but I cannot locate now. Any info on that would be appreciated also
Old 09-19-2018, 08:28 PM
  #1541
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
No "balance shaft" worries on a MY2008. Typical leaks will be around the adjusters on the front of the heads, and the oil centrifuge and cam plugs/caps on the back of the heads. THose are all easy and cheap repairs.
Old 09-29-2018, 07:36 AM
  #1542
principledchiro's Avatar
2006 CL55 AMG
Balance Shaft Issue?
Originally Posted by Rudeney
Kyle, that is M273 engine #65983, which is within the affected range.
Hello, Rudeney, looking in to a Danbury Connecticut Chevrolet dealership selling a 112K mile 2007 CLK550 coupe with CEL on and misfiring. The VIN is: WDBTJ72H97F208101
Thank you
Old 09-29-2018, 10:39 PM
  #1543
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
That one has M273 engine #57433 which is in the range for potential timing chain idler sprocket failure. Personally, I'd not buy a car with the MIL illuminated unless I knew exactly why.
Old 10-11-2018, 12:03 PM
  #1544
Sasquatch1's Avatar
2009 CLK 550 Cabriolet
Please check this VIN-WDBTK72F39T101772. It is an 09 so I don't think so, but it is an July 08 build and I'm not sure. Thanks in advance.
Old 10-11-2018, 12:40 PM
  #1545
D E N S K I's Avatar
04C230, 08ML350, 14E350c, 15C300
Sir Rodney....
Please check 4JGBB86E58A417829 - 2008 ML350. I am having a CEL code P0016/P017. Hoping it is just a magnet and sensor replacement. Thanks!
Old 10-11-2018, 09:15 PM
  #1546
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
2009 are out of the range. No need to check. But if you want your data card, go here:
https://www.datamb.com/
Old 10-11-2018, 09:17 PM
  #1547
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Originally Posted by D E N S K I
Sir Rodney....
It's a MY2008, so it will be out of the range. But that does not mean that parts don't still fail, just not "chronically". I think you need to get a proper diagnosis and pull codes with a tool that reads MBZ-specific DTCs. Those generic ODBII codes each represent four different DTCs. Unfortunately, none of them are easy fixes.
Old 02-04-2019, 04:27 PM
  #1548
Henry Le's Avatar
2006 E350
Could you please check this VIN for me? WDBUF56J16A818724
2006 Mercedes E350 RWD
I try to email global mercedes but they said my vehicle not include in class action lawsuit about balance shaft
thank you
Old 02-05-2019, 10:11 AM
  #1549
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
Yes, all MY2006 V6/V8s are in the range. No need for a VIN check. Only My2007 needs to be checked by VIN/engine serial#.
Old 03-24-2019, 10:45 PM
  #1550
santafeMB's Avatar
no MB currently
Hello, can you check 4JGBB77E47A204992? 2007 ML63. I looked on a few websites and the engine code I found is 156980 60 007218. I assume it is past the impacted engines? Also, any other issues that you are aware of? Thank you. hoping to join the MB community.
You have already rated this thread Rating: Thread Rating: 8 votes, 5.00 average.
Quick Reply: Please check my VIN for Balance shaft issue?
