Tie Rod
Tie Rod
I had some vibrations at 120kmh. I thought the wheels needed to be balanced so I went to a tire store. The guy told me that the left tie rod was loose and should be replaced. Since alignment is required after a tie rod change, I went ahead to get both replaced. Good thing is the vibrations went away.
So, the right tie rod was still good but I replaced it anyway. My question is should I keep it in case I need it later?
Sorry, the right side was loose and that's the whole reason for replacement.
I checked my repair records. The right one was replaced back in June-2006 and the left one was replaced in June-2010. I do about 15k miles per year.
