Low coolant level and washer fluid?
Greetings all!:cheers::zoom:
I have been lurkin the forums for quite some time now, and just finally pulled the trigger on purchasing a clk500! This is actually my first Benz, coming from a BMW which was a nightmare I'm very paranoid about every little thing. The car is currently displaying low washer fluid, as well as a check coolant message. I've checked the coolant level and it likely needs to get topped off a bit. I'm not sure where the coolant is leaking from. The washer fluid is very low, and visually I can see a puddle of liquid right below the washer fluid reservoir on the undercarriage part. Do you guys think this may be related? Is there any hose that I should suspect this leak to come from? I'd also like to note that the car is a MY2004, with a Valeo radiator. Given the common issues with this radiator make, should I preventively get it replaced ASAP? Thank you all in advance! Keep a newbie informed:zoom::newbie::hollab: |
The coolant and washer fluid level sensors are wired in parallel, so if one fails, you get both errors. The leak in the washer fluid is most likely either a bad pump or a bad seal where the pump is mated to the reservoir.
On the Valeo radiator, I would replace it. They all seem to leak coolant into the transmission eventually. |
Originally Posted by Rudeney
(Post 6002215)
On the Valeo radiator, I would replace it. They all seem to leak coolant into the transmission eventually. For the radiator, can you direct me to a website where I can buy the behr one specifically for my car? Thanks for the advice Rudeney!:thankyou: |
You don't say where you are located - please update your forum profile. If you are in the USA, parts.com sells through a dealer network at pre-negotiated discount prices. Other good places to check are rmeuropean.com, autohausaz.com, and rockauto.com.
(Post 6004701)
Also, just encountered another stupid problem... The damn front hood won't open:smash:. I pull the red release latch very hard and hear a clunk, suggesting the hood pop a little. After pulling the black lever in front of the hood, the right side(driver side) opens a little, but it looks like the left (passenger) side is stuck?? This is such a pain in the ***!! Am I doing something wrong?:confused::confused: |
There should be no bad Valeo radiators in the supply chain any more. If you buy a new one, it's almost certain that you'll get the revised Behr part.
As for the hood, you may have a bad latch or cable. Unfortunately, this is a difficult problem. I cannot explain how to open the hood, but it can be done. You have to remove the paneling under the engine and reach up to the latch and disengage it. Honestly, you need "intimate" knowledge of how to do this as it's all done by feel. |
(Post 6005943)
As for the hood, you may have a bad latch or cable. Unfortunately, this is a difficult problem. I cannot explain how to open the hood, but it can be done. You have to remove the paneling under the engine and reach up to the latch and disengage it. Honestly, you need "intimate" knowledge of how to do this as it's all done by feel. I finally was able to get the hood open. Had a friend pull the latch, while I pulled the lever. Squirted some lubricant into the latch and now it seems to be good! I guess it must of got stiff over time. :nix: |
That's good. When the cable or latch mechanism breaks, it's a real PITA to get the hood open.
fluid level sensors
I replaced both sensors.fluid level topped off.still get fault codes how do clear fault code .anybody got the answers. 2007 clk350 conv. |
Check that the washer fluid pump is plugged in. If it;s unplugged, it will trigger both of these errors.
