Check Engine Light '04 CLK500
Old Aug 17, 2014 | 01:04 PM
racerman37's Avatar
2004 CLK500
The light came on in the speedometer, but in paging through the displays, computer says no faults. I had forgotten to screw the gas cap on at a fuel stop and got the warning for that but putting the cap on fixed the warning. Any way to find out why the light is on?
Old Aug 17, 2014 | 05:05 PM
Glyn M Ruck's Avatar
Super Moderator
Scan with an OBDII scanner or Star.
Old Aug 17, 2014 | 06:43 PM
Yidney's Avatar
2008 CLK550 Cab
If your check engine light is on, your computer display won't tell you what is wrong - you have to read it with a code reader. However, it could have been caused by the loose gas cap. That will trigger a code for a leak in the evaporative system. It won't shut off right away. Drive it a few cycles and see if it goes away.
Old Aug 17, 2014 | 10:13 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
I don't know if the pre-facelift model will tell you, but I know my MY2007 did tell me when I forgot to replace the gas cap via a specific message on the MFD.
Old Aug 18, 2014 | 01:06 PM
racerman37's Avatar
2004 CLK500
Dug out the OBDII and got the code. Related to the gas cap. Cleared the codes, Check Engine Light off. All's well again. Thanks to all who posted.
