HELP!!! Foglight replacement
2012 CLS 550 4Matic and 2003 C240 4Matic
I have a 2004 CLK 500; does anyone know how change the foglights and even the headlights. I am not sure if there is DIY page but if so can someone please send me the link or links....thanks in advance to anyone that can help me out
haven't done the foglights but the HID low beams are fairly easy. Make sure the car is off and key out of the ignition first as you can be severely injured. There is a big circular cap behind each lamp. Twist it off. The low beams are held by a spring clip. Twist and remove the wire going to them, then unhook the spring clip. The bulb will pull right out.
