2004 CLK 320 hesitates on acceleration with slow response on taking off
So i got my 2004 clk 320 with a very low mileage but i noticed that the car is almost with no power on taking off from standing position and it has a slow response to throttle, took it for service changed spark plugs, air filter and fuel filters but unfortunately it still the same no power on taking off from traffic light for example. but during driving on the road it response well but not really as it should be compared to its engine size.
please guys if any one had the same late response on throttle advice for solution. |
check oxygen sensors and maf
Originally Posted by mbassir
(Post 6262883)
First step is to check codes. Even if the MIL is not illuminated, you can have some stored errors that might help diagnose the problem.
Also reset the adaptations
Originally Posted by johny1989
(Post 6262886)
Guys please i need help i tried all the possible solutions, changing filters, air filters oil filters fuel filters, also MAF sensor, spark plugs and still has no power in the car she is still so dead no power in take off no power in changing gears the car is not sensitive to the throttle at all any idea please support....
thank you |
Your car needs a thourough inspection through STAR, clearing codes wont fix anything. Take it to an experianced shop who has star and they should be able to pinpoint the problem. Various tests cam be performed through it.
You said your shop reset the codes, but what were they? Also, how many miles on the odometer? The catalytic converters can begin to fail around the 100K mark. As they deteriorate, they spew molten metal down the exhaust pipe which can lodge in the resonators and muffler and cause back pressure, which will really rob performance, often without any other symptoms.
