MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   CLK-Class (W209) (https://mbworld.org/forums/clk-class-w209-43/)
-   -   CD magazine won't eject (https://mbworld.org/forums/clk-class-w209/591687-cd-magazine-wont-eject.html)
themvols Jul 3, 2015 01:19 PM
Magazine in CD changer fails to eject properly in 2005 CLK320. Any suggestions as to the possible problem?
dlevinson Jul 10, 2015 01:47 AM
Fix stuck changer
Had this happen to me as well.
Option a) tap gently/repeatedly with handle of screwdriver + pressing eject every few taps
Option b) remove changer and turn on its side, then start the tapping business again with a little gravity love
My issue was a cdrw being too thick believe it or not. Don't be afraid to take out a few screws, all pretty novice stuff.
Good luck
KENNY94945 Jul 10, 2015 10:53 AM
Pull the fuse (in the trunk) or disconnect the wiring connector connected to the back of the changer unit may also reset the unit and allow ejection.
Common problem...try a search for other suggestions.
dperrow Jul 12, 2015 01:41 AM
Magazine Issues
Along the same lines, my CD magazine just stopped working all together. It is no longer even recognized by the main audio system. Could this be a fuse issue?
Any advice appreciated.
gaazmon Jul 12, 2015 08:48 PM
This worked for me. Pulled Fuse 20 and put it back in. It's a red 10amp fuse. I have the HK sound system so don't know if it makes a difference or for the pre-facelift Bose systems.
© 2026 MH Sub I, LLC dba Internet Brands
