radiator drain plug washer, need?
2004 CLK 55 AMG
i had to replace my red drain plug since it was cracked when i took it out.
it was broken 1/2 way up the plastic threads, so the bottom half of the plug just unscrewed and the metal washer came out with it. i had to use pliers to twist the other half out so the fluid would drain
given this situation, i cant believe the washer was doing much anyways
of course after the flush i forgot to put the metal washer on the new plug. am in for leaks?
