time change problem
Old Nov 1, 2015 | 11:08 AM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
time change problem
So i got to adjust my clock this morning and am having an issue.
In the navi unit i hit the sys button as always, There is the tab there for timeset, but now its lit dim so its something i cant select it.
Old Nov 1, 2015 | 11:23 AM
vsix's Avatar
JBs C63 PP( wifes car ), Mc Laren Pxx(toy), 2013 Mustang GT 5.0 ( DD ), ML 6.3 ( winter DD )...
Hmm usually when something is lid dim and not highlighted anymore, it's indicating no availability at a certain condition. Might be due to running condition instead of the key in just first position, without cranking it...
Just try a few key position's and get back at us.
Old Nov 1, 2015 | 11:25 AM
gixxerboy's Avatar
thanks, i'll go try that. Yes the car was running, i didnt think of that.
Old Nov 1, 2015 | 11:42 AM
vsix's Avatar
Your welcome.
Old Nov 1, 2015 | 06:08 PM
gixxerboy's Avatar
thats not it, with the key just in the ignition the light is lit, if i press it it say key has to be in on position, as soon as i turn it to on position it goes make dim.
Old Nov 1, 2015 | 06:14 PM
FFXF1's Avatar
2003 Chevy Tahoe
Don't know if this helps - the key has three positions: 1) simple electronics (windows & seats), 2) all systems, 3) Ignition. If you're using keyless, do not step on the brake punch the start button once for position 1, twice for position 2. Position 2 is what you want - I believe.
Old Nov 1, 2015 | 09:37 PM
gixxerboy's Avatar
mine has a key not push start.
I've changed my cluster to an amg 63 cluster. Everything works since the change, all the settings, navi, radio controls, but i wonder if this could be the issue? Just seems strange that it would effect nothing else but time change
Old Nov 2, 2015 | 02:55 AM
DanielFD's Avatar
2007 BMW 550i
There are 2 possible reasons. first of all there is no GPS signal which can cause your issue as the gps isn't figuring out where you are. second of all the cluster you have installed isn't communicating with the Commad for some weird reasons which probably means you can change the time from within the cluster. you can code those things through STAR (wither comand manages the time, or the cluster)
Old Nov 2, 2015 | 10:42 AM
gixxerboy's Avatar
the navi def works since the cluster change, but i was in my parking garage when trying to adjust the time. so maybe the gps wasnt getting a signal to be able to adjust it, I never thought of that
I'll pull the car out doors tonight and try again.
Old Nov 2, 2015 | 10:54 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If you swapped clusters, there could be a coding issue. With NAV, the cluster should be coded to get its time from the GPS in the NAV. Without NAV, the cluster needs to be coded so that the time can be set manually on it. I'm not sure what might happen if NAV is present but the cluster is coded for no NAV. Also, there is a difference in the NAV system as to whether they talk to the clusters. Older models have the button labeled "SERV", newer labeled "SYS". The cluster much match or you will have issues.
Also, I just checked my car (I have the older one with the SERV button). I can set DST in any mode - no key, key in position 1, or key in position 2 (car running or not). And in the garage with not SAT signal.
Old Nov 2, 2015 | 11:05 PM
gixxerboy's Avatar
Thanks Rodney, my car is an 09 550 and the cluster is out of an 08 E63. Both had navi and when i use my navi it works through the cluster like it did with the original cluster. The 63 cluster works perfect all the options work the only issue was the expected ----- for odometer and the sos system had an error message in the cluster. But all the steering wheel features work. And the extra features in the 63 cluster like oil temp, gear indicator all work.
i didnt have a chance to pull it outside and re try it. Worst case ill pop in the old cluster and set the time and go back to the 63 cluster.
Old Nov 3, 2015 | 01:41 AM
DanielFD's Avatar
2007 BMW 550i
actually no need for that, just set the time from the cluster itself in the settings menu and not from the command and you should be good to go. My dad's ml350 in an american import and GMT+2 isn't listed as an timezone at all. so i used STAR and made the cluster use degrees Celsius and configured the cluster to set the time and not command. problem solved.
Old Nov 4, 2015 | 03:40 PM
gixxerboy's Avatar
thanks, i was able to adjust it through the cluster itself. Took me a minute to figure out i had to hit the trip reset button after.
Old Nov 5, 2015 | 02:02 AM
DanielFD's Avatar
2007 BMW 550i
Old Nov 15, 2015 | 12:56 PM
paulous75's Avatar
clk 320 w209 2003
Analogue clock setting clk 320- 2003
How do I set the analogue display clock on my clk? step by step please. I'm not having much joy in figuring it out.... I can get to the screen with 'time' on it but not sure how to select it?
thanks, Paul
Old Nov 15, 2015 | 02:00 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Instructions are in your owner's manual. If you don't have one, then you can download a PDF copy from the "owner's" section of http://mbusa.com. It's very simple - you do it through the instrument cluster menus.
Old Nov 15, 2015 | 02:19 PM
gixxerboy's Avatar
Old Nov 16, 2015 | 02:22 PM
paulous75's Avatar
clk 320 w209 2003
Thanks my man!
Turns out the (_ and +) button on the steering wheel is not working.
Hence my inability to set it, so need to investigate it!
