Overheat now won't turn on
Old Mar 8, 2016 | 09:48 PM
SBundlez's Avatar
2011 E350 4matic
Unhappy Overheat now won't turn on
my car temp gauge ran all the way to the top and the temp light came on. red light in the instrument cluster saying to turn car off. I pulled over and cut it off to let it cool. When i went to turn it back on it would start but then cut off.
Any help on what's going on? i'm going to change the spark plugs tomorrow but i have no clue what's causing it not to turn back on even after its cooled off.
Any help would be appreciated
Old Mar 8, 2016 | 10:06 PM
gixxerboy's Avatar
2013 CLS63, 2001 ML430, 2012 e350 coupe
does it crank and not start , or not even cranking?
Old Mar 8, 2016 | 10:07 PM
gixxerboy's Avatar
i would wait on doing plugs, do you know what caused it to overheat that bad?
Old Mar 8, 2016 | 10:22 PM
DRACO's Avatar
85 911 Targa
+1, find the reason for over heat, check the fluids for cross contamination.
Old Mar 9, 2016 | 09:00 AM
SBundlez's Avatar
2011 E350 4matic
it cranks, starts, then dies.
i was involved in an accident 2 weeks ago. the check fluids gauge popped up yesterday.
Old Mar 9, 2016 | 09:03 AM
gixxerboy's Avatar
so it probably was low on coolant, i would check the oil and see if you have coolant in there.
i dont know what tools you have to diagnose it, i would check the fluids and then do a compression check first.
Old Mar 9, 2016 | 09:52 AM
SBundlez's Avatar
2011 E350 4matic
i'll go do that now.
Old Mar 9, 2016 | 09:14 PM
SBundlez's Avatar
2011 E350 4matic
i filled the reservoir with fluid but now the fan is blowing like its a fighter jet.... anyone know what the issue is with this problem?
Old Mar 9, 2016 | 10:09 PM
floridawriter's Avatar
05 CLK55 AMG (1 of 247) Cubanitsilber designo series
CELs? Air bubbles in the coolant reservoir? Coolant boiling out the coolant overflow tank? Milky residue on the inside of the oil filler cap? Why is the coolant level low, where are the leaks?
Old Mar 9, 2016 | 10:13 PM
gixxerboy's Avatar
so you got it to start of the fan is running with just the ignition on?
Old Mar 9, 2016 | 10:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
If the engine suction fan runs at high speed wit the key in the ignition position 2, before starting the engine, then that is a symptom of it and the EC not communicating.
Old Mar 10, 2016 | 04:45 AM
DanielFD's Avatar
2007 BMW 550i
possible water contamination in the ECU/front sam, exactly what part of the car was accident involved in?
Old Mar 14, 2016 | 08:08 PM
SBundlez's Avatar
2011 E350 4matic
It turns out that i had a leak in my hose where it connects to the radiator. the clip wasn't on correctly. and i forgot to connect to connectors on the passengers side of the radiator.... so the SRS and check engine light came off... i just have to replace my radiator and i should be fine. the wind tunnel fan was only because the car was running hot or about to.
