Last part of top closing ?
Old Apr 30, 2017 | 09:34 PM
globalauto's Avatar
s320
Can someone point me in the right direction ? My top when closing will not latch the glass part down to partition panel ? It raises up but will not go down when closing . I have to manually push into it, once the panel goes down all the way , then open the top snd push it down while closing it again ... Thanks in advance ...
Old Apr 30, 2017 | 11:57 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
It's likely a bad switch. Get the error codes stored in the soft top controller.
Old May 2, 2017 | 07:07 PM
globalauto's Avatar
s320
Ok when I tried to open now the back of the top is not unlocking from the partition panel ? It's like the timing is off when it's supposed fold up and down ..
Old May 2, 2017 | 09:45 PM
globalauto's Avatar
s320
Found a broken switch
Can someone tell me the part number on this switch and where to buy ? Hopefully this will fix my problems ? If you look closely you can see it's cracked and that explains the little spring I found in the trunk
Old May 2, 2017 | 11:30 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
Try this:
http://www.mboemparts.com/oe-mercedes-benz/2098201910
Old May 9, 2017 | 04:41 AM
globalauto's Avatar
s320
Fixed , thanks so much !
Old May 9, 2017 | 08:59 PM
globalauto's Avatar
s320
Her is a pic of the top on the side glass
Old May 10, 2017 | 09:50 PM
Rudeney's Avatar
MBworld Guru
NO LONGER ACTIVE
That's a torn waterbag. It can be repaired, but it's a bit of a task:
http://benzbits.com/w209/soft_top/RepairWaterPocket.pdf
http://benzbits.com/w209/soft_top/RearWindow.pdf
http://benzbits.com/w209/soft_top/ExposeWaterPocket.pdf
http://benzbits.com/w209/soft_top/Re...aterPocket.pdf
