Problem with alternator after reverse polarity.
Hello guys!
I am fixing a reverse polarity damages in a CLK 270 cdi. I have replaced rear and frontal SAM units and now all the electrical items are working properly. I also changed the alternator, with a rebuild one but is still not charging. żAny idea of where to continue? Thanks in advance!
I think he meant for you to check the ground points. There may be others to check since you replaced the SAM, but there are probably 2 points under the hood on either side of the car. One near the battery and another near the fuse box.
