OBD2 scanner
Old 06-18-2018, 08:47 PM
redciv1's Avatar
2007 CLK350 Convertible
OBD2 scanner
Looking for a cheap inexpensive obd2 scanner to pull codes, clear and turn off CEL. I bought the Autel MS309 however it is not connecting. Oddly enough it connects to my Boxster, but not the CLK350
Old 06-18-2018, 11:17 PM
MBworld Guru
Rudeney's Avatar
NO LONGER ACTIVE
I hear good things about the Autel MD805. I uses SDS myself, so I don't know much about the Autel, but a bunch of guys over on the benzworld forum swear by it.
Old 06-18-2018, 11:45 PM
redciv1's Avatar
Thanks Rued. I was looking for a little bit less expensive than the 805, although it does pack slot for the money
Old 06-19-2018, 09:34 AM
Anker's Avatar
2009 CLK 350
The big advantage of the Autel is that it supports many brands and models. Never as well as the brand and model specific ones like SDS.I bought the Autel initially because I had both a Porsche and a Mercedes CLK. I regret that now and am sharing a Porsche Durametric with another owner. Next a SDS for the Mercedes.
The money you spent on a good diagnostic scanner is earned back the first time it eliminates the need to take the car to a dealer of independent.
Old 06-19-2018, 11:43 AM
redciv1's Avatar
Yeah Anker. I am in the same boat as the Boxster is fine non the MS309 but the CLK is not. That Durametric sharing is a good idea as I just had to track down Evap errors and SAI issue. But should be good now.
Old 06-20-2018, 12:18 AM
xsever's Avatar
2012 C300 4MATIC Sport
Did you try their Tech Support? I had bought a generic $10 OBD2 dongle and I connect it to my Android phone using Bluetooth and the Torque Pro app and it works wonders.
Old 06-20-2018, 05:55 PM
redciv1's Avatar
You know I just realized, all this time being trying Amazon and need to go through Autel, Thanks
Quick Reply: OBD2 scanner
