how easy to change out steering wheel and gear shifter?
I am looking at a 2003 CLK500 today that has a pretty used up steering wheel and gear shifter. The car could possibly be gotten for $3500 -4000 but I need to know how much to change these things....negotiation power
any help would be appreciated Chaz |
Steering wheel removal is fairly easy. There are a few Torx bolts holding the airbag in place. You remove that, then there is a nut holding the steering wheel to the column. Once that's remvoed the steering wheel comes off straight off - no need for a wheel puller:
http://benzbits.com/w209/SteeringWheelAirbag.pdf http://benzbits.com/w209/SteeringWheel.pdf As for the shifter, you can probably just fix that. Remove the wood panel (it just pops out) and then use some screws to secure it from behind: http://benzbits.com/w209/ShiftSurroundRepair.jpg |
Originally Posted by ChazThePhoenix
(Post 7650942)
The inside of the car looks like what my 2004 looked like when I bought it. It was a mess. The steering wheel you need to also find a matching airbag cover as well. The shifter is not hard to find. If you get a wood wheel you need to attempt to match the wood to the rest of the trim. Your seats have the same wear on them as mine too! I thought it was due to going to the beach and all that but it must be common.
(Post 7650942)
Originally Posted by dzmitry
(Post 7651957)
BTW, if you're looking to restore you interior just PM be I know coupe of tricks ;)
Originally Posted by C280 Sport
(Post 7653720)
Make a thread about it. It will be useful to other CLK owners.
Just replaced my steering wheel and i took out the shifter to re wrap it .
1.The steering wheel is easy 2 bolts behind the steering wheel hold the air bag . The bolts don't come out they just loosen it till its the air bag is loose . Make sure you put the steering wheel back to dead center. 2 Now disconnect the negative terminal on the battery 3. Now you can disconnect both connection on the air bag . be careful and use a small flathead . 4. Now you will see a big bolt on the steering wheel . You will need a torque wrench . If its small you need a breaker bar as its on tight . whether tightening or lessening the bolt always make sure your pushing down on the wrench if you go up you can hit the windshield . 5. Don't not turn the clock spring on the column or try to play with it . 6. Use threat locker and torque it down to 100 ft lb and put everything in reverse . ---------------------------------- 1. For the shifter get a plastic tool or use your hand and pry under the chrome strip . 2. There is a round plastic nut on the bottom of the shifter. loosen it and it you can remove the shifter |
