2003 CLK320 obd2 no link issue...new member
2003 CLK320
Hi there. I知 looking for some direction with my CLK. CEL came on but I知 unable to pull any codes. I致e tried 3 different scanners with no luck. Checked my diagnostic fuse under the hood # 62 {good}. Any input is greatly appreciated.
MBworld Guru
Welcome to the forum! Please take a moment to visit the User Control Panel and update your profile to include your your location (at least country). This information will then appear below your name and avatar on the left side panel next to each post you make. This will greatly help others to give you better information. If you are using the mobile version of the site, you will need to switch to the "full" version to get to the User Control Panel.
Although not the best choice, generic OBDII scanners should work just fine on your car. You also might want to check that the wiring is good on the connector. You can remove the under dash panel and access it from behind. I do recommend getting a scanner that reads MBZ's proprietary codes and systems. The iCarsoft i980 or MBII or the Autel MD802 Elite are all recommended by forum members.
2003 CLK320
Thanks for the warm welcome. I took a minute and updated my profile. I値l check the back of the obd port and let you know what I find.
