CLK350 top issues and now starter?
My recently inherited 2009 CLK convertible has had issues with a wiring harness blocking the trunk partition from coming down. Even after moving the wiring harness out of the way, it still ends up back in the same place after opening and closing the top. I had read on the forums how to secure the wiring harness to the trunk wall and was attempting to do this when my minor nuisance turned into a major problem. I was inspecting this wire from above with the top partially open, but didn’t actually change anything. After that I could no longer open or close the top. Dash says top in motion but it wont move.
So the top is 90% closed but is stuck in that position- won’t close and won’t open. And to top it off now the engine won’t start! Electronics seem to work but the starter makes only a weak attempt before giving up. No joy with an attempted jump start either. Is this bizarre situation a coincidence or the result of something I did? I assume the engine would normally start even with the top in a midway position. Any suggestions before I have the car towed? Thanks! |
First of all, it sounds like your battery is dead. When trying to jump it, connect the jumper cables and then disconnect the negative lead from your battery to take it out of the circuit. A bad cell can make it act like a huge resistor and even a jump won't overcome that for enough power to crank (or operate the top).
If that doesn't do the trick, you can manually operate the soft top. Instructions are in the owner's manual, and here's a video showing the process. They used an A20 E-Class, but it's identical to the W209 CLK: http://benzbits.com/w209/soft_top/ManualClose.wmv Also, if the partition does not stay in place, you should replace the Lift-O-Mat struts on it. They are available here (assuming you are int he USA): https://www.rmeuropean.com/Products/...59-MFG624.aspx |
Originally Posted by Rudeney
(Post 7733318)
If that doesn't do the trick, you can manually operate the soft top. Instructions are in the owner's manual, and here's a video showing the process. They used an A20 E-Class, but it's identical to the W209 CLK: http://benzbits.com/w209/soft_top/ManualClose.wmv Also, if the partition does not stay in place, you should replace the Lift-O-Mat struts on it. They are available here (assuming you are int he USA): https://www.rmeuropean.com/Products/...59-MFG624.aspx https://mbworld.org/forums/clk-class...k-320-a-3.html |
Rudeney you were 100% correct- the battery was dead. I was able to jump start it today after charging my booster pack overnight. Apparently 75% charged wasn’t enough. The top operates too and did not require manually closing. Thanks!
When I worked a the dealership, we had dead batteries all the time. Cars would sit on the lot for months unused. The sales department had a portable jump pack they'd use, and it rarely worked. The service department had a large rolling unit that was a bit better, but often the only way to get one started was to disconnect the dead battery.
