Clk55 cams on 500 engine
Old May 26, 2019 | 12:58 AM
eight8's Avatar
W220 S500
Hi everyone,
I was told that installing cams from the Clk 55 in a Clk500 engine is a direct swap. But I am not sure if It is required to change the valve springs and retainers as well.
From what I’ve read, the preface lift C55 had single valve springs, whereas the facelift C55 has double valve springs.
Would appreciate if you guys could advise me which parts I need to swap other than the cams to do the job correctly first time.
Steeve
Old May 26, 2019 | 11:28 AM
insame1's Avatar
2006 E55, 2012 GLK350 & 1992 190e sportline
Did they actually do a facelift on the c55. They only made them for like 2 years.
