brake pad replacement
Need to replace brake pads front and back. Any suggestions on what type/brand semi-metallic or ceramic? Non-sport. Also, would I require a torx wrench for the job?
Thanks for any advice......... |
I just replaced the front pads (and rotors) on my CLK550 with Brembo parts from autozone.
The front pads only required 2 pins to get tapped through the caliper. I used a very skinny screw driver. The pads slide out of the caliper without removing it. No torx required. Very easy, maybe 15 minutes per side. Mine have the 4-pot front caliper, not sure about your 350. |
In my experience i have found that genuine MBZ pads perform the best. I've tried Akebono (which were crap) and Porterfield Kevlar pads, which were only about 90% as good as OE pads. Yes, the MBZ pads create black dust, but I;d rather spend time cleaning wheels than cleaning up after a crash. As for rotors, genuine MB are good, but I also like Zimmerman.
Originally Posted by Rudeney
(Post 7777787)
I agree with Rodney. I love the feel of the MB OEM pads/rotors. |
Originally Posted by ambit
(Post 7777455)
The front pads only required 2 pins to get tapped through the caliper. I used a very skinny screw driver. The pads slide out of the caliper without removing it. No torx required. Very easy, maybe 15 minutes per side. Mine have the 4-pot front caliper, not sure about your 350. Thanks, Don |
Originally Posted by don30068
(Post 7778144)
Are you using semi-metallic pads?
https://www.bremboparts.com/asiapaci...ue/pad/P50053N |
