MBWorld.org Forums
MBWorld.org Forums (https://mbworld.org/forums/)
-   CLK-Class (W209) (https://mbworld.org/forums/clk-class-w209-43/)
-   -   door disassembly (https://mbworld.org/forums/clk-class-w209/747689-door-disassembly.html)
irokdastar 06-16-2019 10:59 AM
door disassembly
Hello Everyone . Happy Fathers day ! I am trying to take apart the door panel itself . I want to replace the material that's on the outside of the door pocket all the way on the bottom . Can I take this door panel apart or is everything pretty much plastic welded together ?
Rudeney 06-16-2019 09:57 PM
Plastic welded. But you can still work on it. You'll just need to use epoxy to reassemble it after drilling out the the plastic "rivets".
irokdastar 06-17-2019 11:18 AM
Thank you. I didn't wan to attempt it without knowing .
