W209 roof wont open
Mercedes Benz Clk w209 convertible
W209 roof wont open
Hello guys, i am trying to open the soft top but nothing happens. When i press down the button in order to open, i get the message top in operation. However nothing happens, no windows go down no sound. Although when i press up the button i can hear the pump for a few seconds. The fuse is ok and i swapped the relays with 2 that i had in a spare pump but i still get the same symptoms. Am i so unlucky that the spare relays are bad too or something else is wrong?
Take a look at Rodney's thread https://mbworld.org/forums/clk-class...ostic-aid.html
I had a similar problem a few years ago... I ended up taking it the MB dealer, where it was diagnosed. They figured out two relays had failed (or maybe one failed but they changed both). I would try that.
I do remember that not only the roof was not working, but also the trunk. Both problems were solved w/new relays but the trunk had to be “re-activated”.
I bought the two relays but nothing new happens. The windows are not going down. I realized that when i i turn on the engine, a red light in the roof button lights, it also lights when i try to open the top.
