Catalytic converter dimensions needed
Old Sep 19, 2023 | 12:03 PM
karayjay's Avatar
2006 CLK 350/. 2009 CLK 350/2005 Both White
I have a separate post on this issue that I’m having with an engine misfire and only happens under load never happens in neutral or park when you read the engine.
Also, when you start to give it slight load, you can feel it about to go into check engine mode when you’re back off and throw it in neutral it revs fine, so I’m thinking I need to replace a catalytic converter passenger side since it’s on the one giving me a misfire
this one’s worked out for me for my C240 and I want to try to get where I purchase a bullet type catalytic converter and have it welded in rather than spend big big money. If I can just purchase an $50 cat and have it welded in for another 80 bucks it’s worth a shot.
