Do 03+ E55 wheels fit on a 03+ CLK55 W209?
Old Jan 29, 2007 | 01:20 AM
JBFMCAR's Avatar
G63, 360CS, CLK63 BS, 997.2TT, 328D
Ive been trying to find this out do the 03+ E55 wheels fit the W209? I heard somthing between some benz's that make some not fit others but i was under the impression that the S/E/SL/CL class wheels for the most part fit the CLK W209 platform. Any information would be great im looking to pick up some wheels very shortly.
Justin Falla
What exact fitment guidelines do i need for 19 inch rims if i decide to go that way? I know 5x112 but what size lug nut 12 or 14mm? what is the widest you can go on the rear 10in?? and what is the offset range i can run for the front and rear?
Old Jan 29, 2007 | 11:01 PM
MadHorseDisease's Avatar
02 CLK55 AMG
You may have already done this but just in case, go to the Tire Rack (www.tirerack.com) and you can gain a wealth of knowledge before you settle down on a wheel / tire combo even if you do not buy one of there wheels.
You will also want to calculate the circumference change (if any) your new set will have over your stock rims and tires. Some people don't care about overall ratio differences but I like my speedo to be accurate and a smaller overall circumference over stock at the rear wheel means slower ET's.
Just my thoughts… Let me know if you need help calculating the ratios.
Happy shopping...
Old Jan 29, 2007 | 11:17 PM
02 CLK55 AMG
Oh, I almost forgot... Everything I saw at a quick glance tells me the E55 rim should fit your W209 but double check with a trusted source to make sure.
I see a lot of 19x10's available for the rear on a W209 so that should support at least a 11.5" rear tire width. I have 17x10.5 FR500's on the back of my stang with BFG KD 315/35-17's which are slightly over 12.5" wide when mounted.
Trust me, anything over 9" wide rims demands a second look. It is definetly worth the extra dough for a wider rear IMO.
Last thing is if your car is lowered, the wheel offset will be one of the most important things to know. Depending on how low your car is lowered (if at all), you may have to calculate the width of your rear wheel from the offset to the tire's outer edge so that it "tucks" under the fender and doesn't rub when people sit in the back seat.
Just my thoughts… Let me know if you need help with anything.
Happy shopping...
width of the wheel.
Old Jan 30, 2007 | 02:39 AM
CynCarvin32's Avatar
Mercedes Benz
while wheel size is important the off-set is even more important for that given size. Some 18x8 and 18x9 wheels will fit and others will not.
Check the off-sets with wheels that are made to fit the car and see how they stack up. A mm here and a mm there will make a wheel not fit so check twice or three times to make sure before you plunk down the $$$.
Old Jan 30, 2007 | 02:40 AM
Mercedes Benz
Check the off-sets with wheels that are made to fit the car and see how they stack up against the E55 wheels. A mm here and a mm there will make a wheel not fit so check twice or three times to make sure before you plunk down the $$$.
Old Jan 30, 2007 | 09:35 AM
02 CLK55 AMG
Old Jan 30, 2007 | 11:41 AM
x-tian-230k's Avatar
CLK500/Range Rover HSE/E55 AMG/Bmw 328Xi coupe/BMW 4.8x/Bmw 335i/GS350/Audi S5/E350
I dont think they will fit...you will have some rubbing issues....
Old Jan 31, 2007 | 01:05 AM
AMG_55's Avatar
mymbonline
the widest rear tire you can put on a 209 on a 19in wheel w/o rubbing is a 265, i had a 275 and there was minimal rub (i didnt give a ****). the fenders near the bumper had to be grinded down though
go w/ 8.5 235 fr. and 10 in 265 or 275 rr. on 19's
Old Jan 31, 2007 | 09:19 AM
Its a combo of the tires and the offset of the rim. Again, i believe it will rub...
