I have found a set of 5 series 19x8.5 and 19x9.5 HREs local we put them on the car today and sized them up the front offset was perfect with the 235-35-19s and the rear was a little bit to much offset which required a 15mm hubcentic spacer to size up correctly this rim has a 265-30-19 mounted on it. Now my concern is they have the 14mm bolt holes and my W209 CLK55 has the 12mm bolt holes is this going to be an issue is there a certain bolt in which i need to order or is this just not going to work?
Please let me know asap these wheels are in mint shape and were just used for one month.
Justin Falla
Justin Falla
Currently Active Users (1)
