Anyone mess with gearing?
Old Mar 19, 2008 | 07:59 PM
blackbenzz's Avatar
haters crazy
Has anyone tried swapping out diffs? I think alot can be gaine din the 1/4 mile by going to a different diff. Anyone have experience?
Old Mar 19, 2008 | 11:24 PM
DZ111's Avatar
2006 CLS55, 2006 CLK500, 1954 Lincoln
I have done it in other sports cars and it makes a very noticable difference. I have yet to see anything available for ours yet.
Any MD shows or meets coming up soon?
Old Mar 20, 2008 | 09:46 AM
blackbenzz's Avatar
haters crazy
There are mb diffs available with 3.06 gearing compared to our stock 2.82
HIN is coming up April 19th. We have lots of local meets, just check out euromodder.com Its the local euro board and we have pretty frequent meets
Old Mar 20, 2008 | 02:40 PM
rsr911's Avatar
2003 AMG SL55, 2002 AMG CLK55, 2002 AMG ML55, 2005 ML350, 1995 S320 LWB - totaled
Look into Quaife rear ends they can be modifed to fit and are Top quality units.
Old Mar 20, 2008 | 05:05 PM
neilbo75's Avatar
2002 CLK 55 AMG Coupé
It's a good question - and hard to answer with a real life example. The CLK 63 Black Series gets most of its acceleration boost over the regular 63 by changing the final drive ratio.
Old Mar 20, 2008 | 05:55 PM
Ted Baldwin's Avatar
300ce
.............Yes I have a 3.06 gear ratio in my W210 E55 Kleemann.
Ted
Old Mar 20, 2008 | 09:44 PM
blackbenzz's Avatar
haters crazy
Ted
How do you like it? Is traction nonexistent in lower gears or did it actually help? I'm guessing you are using a C43 diff. Thanks for the info
Old Mar 21, 2008 | 12:53 PM
300ce
.........I like it because it makes the car even more of a monster. However, you are right, traction is non existent in "summer mode." I drive the car in winter mode.
Ted
Old Mar 21, 2008 | 01:41 PM
blackbenzz's Avatar
haters crazy
Ted
Are you referring to the current setup or back when you had lower boost? I'm sure with the current setup it would blow the tires off no matter what gearing you used lol
Old Mar 21, 2008 | 05:21 PM
300ce
.............I was talking about back when I had lower boost. Now Summer mode is out of the question. Honestly, I don't think the 3.06 gear ratio will make a Kleemann car faster. There is so much low end torque that the advantage is wasted on the pavement by virtue of shreaded tires. It is fun in that it transforms the car totally. I can see how a more aggressive gearing in the CLK63 BS helps it. But I will probably not help a W211 E55.
Ted
