Please look at this photo of a CLK 55 engine and tell me if there's something wrong
Old Jul 22, 2008 | 07:26 AM
pagepro's Avatar
Hello,
Would appreciate some feedback from current owners of 209 CLK55. I'm about to purchase this 03 CLK 55. The car is generally in top condition, with only one strange(to me) exception, the engine bay.
As you can see from the photos, the engine does not seem to be mounted straight. Is it the engine, or engine cover? Is this normal or something to worry about?
If its the cover, can it be realigned? I understand that the airfilters are housed on the back engine cover hence, it sounds strange that the cover counld be mounted wrongly.
Would appreciate some feedback.
Thanks.
Regards,
P.
Attached Thumbnails Please look at this photo of a CLK 55 engine and tell me if there's something wrong-imag0047.jpg   Please look at this photo of a CLK 55 engine and tell me if there's something wrong-imag0048.jpg
Old Jul 22, 2008 | 07:40 AM
MARTYMAR's Avatar
07' IS 350, 08' E550
Originally Posted by pagepro
Hello,
Thanks.
Regards,
P.
Ewww That does look a bit akward. It could be the cover but then again maybe not because the cover has to fit right on top of the engine mounds which should align perfectly with the cover etc...I don't know man. As long as you know without a shadow of doubt that the car hasn't been in any accidents or had any major damage done to it whatsoever then you should be fine. I am so picky and that would be a reason for me to pass on the car and look for another one. Good luck with your decision! I'm sure others will be responding to your question shortly.
Old Jul 22, 2008 | 10:06 AM
cindyclk's Avatar
The cover is held on simply with 4 clips that pop onto 4 rubber knobs. The back center hooks into the air intake (just above MAF sensor). The cover pulls off with little effort. I believe that the cover is just not attached correctly. If you are planning to buy it and have been able to take these pics, you should be able to go back for another look. lift the front slightly to see if both of the fronts are popped in. By the looks of the pictures they are misaligned and one will not be opped on. If this is the case, the opposite rear is probably also not hooked. If this is so...pull the whole air filter cover off. To put back correctly, line up the the back of the filter over the air intake...press down. The rear 2 clips should pop on as you push down, then the front 2 need a little push and you're done. Takes 30 seconds to complete. If after this, it still looks like your pictures ...run away real fast!
Old Jul 22, 2008 | 11:39 AM
blackbenzz's Avatar
haters crazy
The cover is on wrong. Pull it off and put it on properly. The "hole" by the oil filter is supposed to go over the oil filter cover.
Old Jul 22, 2008 | 12:11 PM
E43 S's Avatar
'00 S-500, E-430S, '88 Mustang
I was about to say the same thing......... good catch
Old Jul 22, 2008 | 12:46 PM
M-bENZ's Avatar
Corrolla
Old Jul 22, 2008 | 01:38 PM
BelaMeca's Avatar
From: Los Angeles,Belgrade.Current Residence Zurich.
2017 Mercedes Benz E220D/GONE!JUNK!Current GLC Coupe 350d 4 Matic
That's what hapens when people try to put an AMG engine cover on a non AMG Engine....jk
Old Jul 22, 2008 | 02:12 PM
MARTYMAR's Avatar
You're crazy dude!
