keyless GO,No GO
keyless GO,No GO
My keyless go don't wanna go no more,it's just keyless now.
I can get into the car just fine but can;t start the Car with push start button.
But then i was playing around with it a bit,and if i move the shifter down slightly when in park,and hold it like that,it would start it.However it will turn off when you move the shifter back,just a little bit...Otherwise i can start the car just fine with the key in the ignition....Anyone had problems with the keyless NO GO?
So far, no problems with my keyless go in the '04 CLK55. I try and alternate between Key and Keyless. Sounds like something is loose with the button and the shifter.
