clk55 spacer help?
Old Apr 9, 2012 | 06:29 PM
jazzo's Avatar
clk55 amg w209
Question clk55 spacer help?
i have a clk55 w209 with 19 x 8.5j rims all round, the rears should have been 9.5j i think? because they look set to far in compared to the fronts, so i was thinking of putting spacers on the back wheels only to give it a wider stance, what size spacers would you guys recommend? is it okay just to put them on back wheels only?
Old Apr 10, 2012 | 02:50 AM
Kevwood's Avatar
'05 C200K SS, '05 Kleemann CLK500K, '08 Hummer H3 & '92 Z34 5sp (track car in Canada)
I had ET35 wheels on the rear and added 10mm spacers to bring the ET to 25, sat really nice and flush. And yeah, you can run them on the rear only if you wish.
Old Apr 10, 2012 | 06:07 AM
j4zzo's Avatar
clk55 amg
Thumbs up
thanks for that, i will probably go with 12mm spacers on the back as they are the smallest hubcentric spacers i can find. i am also thinking of H&R lowering springs which give a 40mm drop roughly all round, will these be okay with my 19" alloys? im running 225/35/19F AND 255/30/19R will it clear the arches and not rub? also will the ride quality suffer with these springs on standard amg shocks? sorry with all the questions but i want to get it right first time, ive read eibachs are not as good as H&R or Brabus springs thats why im leaning towards the H&R's, and i cant find a place that sells brabus springs in UK.
Old Apr 10, 2012 | 08:46 AM
Kevwood's Avatar
I was running 265's in the rear with a total ET of 25 and dropped on H&R, with the camber set to factory specs the tires would catch the outside fender lip once in a while going over large bumps or dips. My track set up but a little rear camber in the rear and I never had any issues after that. My new custom wheels (also ET25) and Invo 265's have never rubbed.
The extra 2mm of the 12mm spacers would most likely get a 265 rubbing but you may be okay with the 255. As much as it doesn't make sense, all cars are slightly different, some guys have no issues and others have tons running the exact same setup...
Good luck.
Old Apr 10, 2012 | 10:09 AM
ecampbell's Avatar
2008 BS
Just my opinion but if you should avoid spacers at all costs and get a set of rims that fit better.
Old Apr 10, 2012 | 11:47 AM
j4zzo's Avatar
clk55 amg
Thanks for the comments I will probably order my spacers and springs this week will let you know how I get on.
Old Apr 10, 2012 | 03:04 PM
Kevwood's Avatar
Good luck and looking forward to pics pal
