HID Question
Old May 18, 2012 | 01:56 AM
400HP55's Avatar
2001 CLK55 AMG
HID Question
I was wondering if I can get stronger light bulbs for our head lights being that they have 2001 technology and such.
Can anyone tell me a little more about our HID head lights? What kind of bulbs can we run in them? Can I change them out for new and improved ones?
Thanks!
Old May 18, 2012 | 10:53 PM
lowpost's Avatar
2018 E43 | 2017 GLS450 | 2004 CLK 500
You sure you have HID?
Old May 18, 2012 | 11:49 PM
400HP55's Avatar
2001 CLK55 AMG
Is this HID?
Old May 19, 2012 | 04:18 AM
lowpost's Avatar
Look like it. I didn't realize 01's had HID
Old May 19, 2012 | 05:17 AM
400HP55's Avatar
2001 CLK55 AMG
I was also wonder about the plastic cover design. Is it designed that way to reflect more light or was it just a cheaper mould? I'm thinking about trying to get clear covers.
Old May 19, 2012 | 05:40 AM
raymond g-'s Avatar
99 E320
from memory, MB didn't offer projector lens design for your model/year so based
on the manner in which you've phrased your question, you have the reflector
based, D2R bulb.
so, no...you cannot simply replace the outer lexan lens and replace with a clear
lens. to get that, you would need to look into aftermarket headlight of the
projector design and very likely, retrofit a OEM projector in its place to get a
quality beam.
jumping back to your original question, if it as I suspect, your D2R bulb is about
1/2 to 1/3 of the brightness being used in the latest D2S or D1S bulb.
bottom line: it *is* possible to convert from your current headlight bit it may
prove to be a little expensive.....possible $500+. will depend on whether an
aftermarket exist in the projector design
(i can barely see the headlight in your sigline...and it does appear to be reflector based)
Old May 19, 2012 | 04:53 PM
400HP55's Avatar
2001 CLK55 AMG
So if i was to remove these lens's I would lose quality because these lenses intensify the beam? These are the "Lexan Lens's?"
Theres better pictures of my head lights in my tear down thread.
Old May 19, 2012 | 06:31 PM
raymond g-'s Avatar
99 E320
the lens are computer designed to focus (not intensify) the light beam. if you
remove and replace with clear lens, the resulting beam would suck, glare,
become unfocused.....but your car might look cool just sitting in the daylight
if you're looking for more modern, projector headlight, you homework should be
to determine if such a design exists for your year/model. if one is produced,
it will likely be a halogen design. this is 75% of the battle.
next would be to bake open and remove the halogen projector inside. replace
with HID projector from an MB (or other OEM, depending on your skill). buy
D2S bulbs, reuse your Hella ballasts. flame on.
your idea of simply replacing the plastic prismed lens is unwise and unsafe
ps...see attached (for example). if these fit your year/model, it's a huge
start towards retrofitting your headlight to a quality HID. next stop is to
see if any of your colleagues in this forum have done this mod. if so, probe
for their insights and experiences. also visit HIDPLANET dot com
pps... i'm not just guessing at this, i've done several of these conversions for 210s
File Type: pdf
Old May 19, 2012 | 10:23 PM
400HP55's Avatar
2001 CLK55 AMG
Very interesting. So whats the difference between HID and Xenon?
I keep seeing light bulbs such as 3500K 5500K 10000K and different colors. What does this mean?
Old May 20, 2012 | 01:59 AM
raymond g-'s Avatar
99 E320
HID refers to "high intensity discharge" bulb which does not utilize a wire filament.
instead there is a gap and the light produced jumps between electrodes like a
lightening bolt, electronic flash etc
xenon is gas used within a bulb (can be filament or non-filament) which allows
a brighter burn/light
many people refer to HID lights in generic, shortcut fashion as 'xenon' even
though this may be technically imprecise.
"3500K 5500K 10000K and different colors...." refers to the color temperature
produced by the bulb. be clear that this does not mean heat temperature but
color....measured using the Kelvin scale. as you can see, when you move
beyond 5000ºK the brightness decreases and defeats the purpose of gaining
the brightest light possible out of an HID headlight design.
Old May 20, 2012 | 10:58 PM
400HP55's Avatar
2001 CLK55 AMG
So I take it we can change our low beams to different colors? The same with high beams?
Old May 21, 2012 | 01:08 AM
raymond g-'s Avatar
99 E320
So I take it we can change our low beams to different colors?....
technically, yes. but the problem with your first gen D2R is that there isn't a
market base to support producing them. from a consumer point of view, your
options to select different temperatures/colors is limited to 1...possible 2.
....The same with high beams?
high beam uses H7 halogen so you have several commercial options limited to
OEM yellow, aftermarket blue hued yellow (looks a hint of white)...but not many
more options. most folks who go this route aren't interested in going HID due
to cost so they buy 'premium' bulbs which are slightly over-driven, or the bulb
has a blueish coating. you can also buy off-road H7s which come in 60, 80
or 100 watts....all technically illegal on US public roads (but I use on my m/cycle)
Old May 21, 2012 | 05:46 AM
400HP55's Avatar
2001 CLK55 AMG
I was thinking about converting mine to projector but nope thats to much BS I rather take that $$ and dump it into headers.
Old May 21, 2012 | 03:00 PM
raymond g-'s Avatar
99 E320
__________________
it has nothing to do with reflection, but refraction. it isn't going to get any
brighter, even if you changed the plastic. you're stuck with the brightest light
you can get out of a D2R bulb.
let's say you are able to locate clear covers for it. you make the swap out
and may still find they don't interchange. if they do, what is guaranteed is
that your beam pattern will go down the toilet, you'll likely incur a traffic violation,
failed equipment citation, and your car will be keyed by folks you've
blinded.....and your girlfriend will dump you.
why? because you've effectively replaced your focused low beam with an
unfocused/full beam halogen....which is basically giving you two pairs of high
beams.
Old May 22, 2012 | 02:43 PM
elijah's Avatar
Euro Cars Only
Good lord! Raymond knows it all lol
Old May 31, 2012 | 10:57 PM
400HP55's Avatar
2001 CLK55 AMG
Thanks for all your help guy's. I leave tons from all of you!
Does anyone know the part # for our tail light bulbs (3 of them per rear tail light- 6 total)? I put some in but they were the wrong ones and melted my tail light housing F%^(*.
I also need to know the part # for our head light turn signal lights (orange ones, I think the tail turns are orange as well - maybe the same bulb.) One of them burned out so might as well replace both front turn signals while I'm at it.
Thanks guys!
PS - I think these are them?
Amber turn siglan bulb - Front or rear bulb possibly?
http://www.rmeuropean.com/Part-Numbe...2-3bc79842fc11
Tail light bulb?
http://www.rmeuropean.com/Part-Numbe...3-70c224201911
Old Jun 1, 2012 | 12:03 AM
raymond g-'s Avatar
99 E320
save this link
2001 MERCEDES-BENZ CLK (w/4 H/L)
High beam headlight
H7
Parking light
64132
Front turn signal
2827
Front turn signal
1156A
Rear turn signal
7507
Tail light
7225
Tail light
5007
Stop light
7225
Fog/Driving light
H1
License plate
6418
Back up light
7506
Front sidemarker
5007
Rear sidemarker
7225
Glove box
6418
Map light
2886X
Dome light
6411
Step/Courtesy light
6418
Trunk/Cargo area
6411
Old Aug 1, 2012 | 09:25 AM
400HP55's Avatar
2001 CLK55 AMG
So I was wondering about our fog lights as well. Are there fog lights we can replace our OEM lights for better lighting? I know our fog lights cant be as complciated and our head lights. I saw some fog light kits out there.
Has anyone changed there fog lights? what would be involved in this project?
Thanks again guys!
Old Aug 20, 2012 | 05:29 AM
400HP55's Avatar
2001 CLK55 AMG
Another question I had is:
Has anyone tried these?
High Beams - H7 Silver Star Ultra
Low Beams - SilverStar HID Xenon 5000K
