New driver of Clk55 Amg 2003----urgent help plz :(
Old May 21, 2012 | 03:20 PM
lchoufani's Avatar
clk55 amg
I recently bought a clk55 Amg 2003 I was driving it and I wanted to test it so i drove it hard and I got "coolant check level"
I took it to the mechanic and it was leaking so I changed the coolant today, I took it for a ride to test it but it didn't work and the temperature got high and again I got the malfunction "coolant check level" when I drive slow it's normal and nothing happen but when I go fast and a lil hard the temperature gets high and the malfunction appears again
Plz if someone knows what to do tell me I've been driving the car for less than 1 week
Old May 21, 2012 | 08:47 PM
betrezra's Avatar
C63 507 AMG DA Car #19
If car does not overheat or lose fluid when driving normal highway speeds and around town, then you say it overheats and/or loses coolant after hard driving?.
could be as simple as a leaky rad hose...... or as involved as a blown headgasket... or bad water pump..... or bad elec fan........ I would find a reputable shop and get her checked out.
You do not want to overheat this motor...... al heads and high heat not good.
GL>
Old May 22, 2012 | 07:30 AM
lchoufani's Avatar
clk55 amg
Changed the coolant and the coolant sensor today and everything is back to normal
Old May 22, 2012 | 07:48 AM
400HP55's Avatar
2001 CLK55 AMG
And now your officially addicted to MB World
Old May 22, 2012 | 01:33 PM
bobbyjo9's Avatar
02 clk 55, 13 GL 450
Just wanted to add... after you did the second coolant change, make sure you have the ratio correct. If you have too much coolant to water it will run warmer. It's the water that disapates the heat.
Old May 22, 2012 | 02:38 PM
elijah's Avatar
Euro Cars Only
Congrats & enjoy the ride!
Any modification plans?
