License plate LED bulb issue
Old Dec 26, 2013 | 01:14 PM
jkiddd33's Avatar
2005 E55 AMG
2004 clk55.
Error free led bulbs for the license plate. Right side works fine however the left side flickers and is off majority of the time.
Tried multiple bulbs same issue.
Does anyone have experience with this and know what the problem may be?
Old Dec 26, 2013 | 02:32 PM
2MCHCAR's Avatar
Supercharged CLK500,ML500,S580
Originally Posted by jkiddd33
2004 clk55.
I have the exact same problem, the passenger side light will always work and the driver side will flicker or not work at all. No matter what type of built in resistor LED you use, it will eventually burn out within a year. I'm using the OEM halogen lights for now.
I have found a solution, but it's a lot of work so I have postponed my installation (I do have the resistors already). I have placed a link to the thread below.
Good Luck!
https://mbworld.org/forums/clk-class...s-problem.html
Old Dec 26, 2013 | 03:38 PM
jkiddd33's Avatar
2005 E55 AMG
Thanks for the info.. Yeah def too much work to get a bulb to work
So this seems like a common thing on the 209? I had no problems on my 209 or 211.
