w208 kleemann headers
Old Aug 22, 2014 | 09:38 PM
Quant's Avatar
2002 CLK55
I recently got kleemann headers installed but they seem to touch steering when wheel is almost fully turned. I know some ppl have had similar issues, is there a work around? appreciate any advice
Old Aug 23, 2014 | 04:22 AM
MouTine's Avatar
'14 E500 Coupe
Same issue here. You got two options. You hit a dent into primary tubeing where steering arm is touching or you grind a small lobe into steering arm. I went with last one. No touching any more except some rare situations when I give sudden hi rpms and wheels are fully turned.
I got to ask you the same question that I'm farming here all the time I here some one is useing Kleemann headers with W208... Do got any pulsation ticking sound from the headers when the engine is under load? Damn anoying ticking noise like its leaking but its not. Can't find any leaking spots or smell gasses.
Old Aug 23, 2014 | 07:13 PM
Quant's Avatar
2002 CLK55
can you describe the issues that you're experiencing with steering pls.
On your other issue, it might be related to your tune.
Old Aug 23, 2014 | 07:23 PM
blackbenzz's Avatar
haters crazy
You can put a dent into it or it will get dented over time lol. The other option is grinding the arm as mentioned.
Old Aug 24, 2014 | 03:12 AM
MouTine's Avatar
'14 E500 Coupe
Heres the picture if it helps.
