Did they forget to give me one at the factory?
Old Aug 30, 2014 | 11:45 PM
City Rat's Avatar
Veteran: Army
Currently: 2019 E450 AWD, Previous: 2002 CLK55 Cab
Guys, I have been trying to chase down the source of a bad bulb light message. I found it, I think, the passenger side inner tail light. Normally it would pop on when you turn on the fog light with full rear tails on. I pulled the cover off the underside of the trunk lid so I could get the old bulb and buy a replacement. Imagine my surprise when I saw two inner tail bulbs on the drivers side but only one on the passenger side. There is a slot for a second one but it still has the factory punch out in place over the opening. Easy to punch through but I wasn't sure if this was normal or if I need to get both a new bulb for the upper position and a new bulb and housing for the other.
Attached Thumbnails Did they forget to give me one at the factory?-img_20140824_175031.jpg   Did they forget to give me one at the factory?-img_20140824_175028.jpg   Did they forget to give me one at the factory?-img_20140824_174946.jpg   Did they forget to give me one at the factory?-img_20140824_174931.jpg
Last edited by City Rat; Aug 31, 2014 at 06:03 PM. Reason: can't spell when I'm sleepy
Old Aug 31, 2014 | 04:59 PM
MouTine's Avatar
'14 E500 Coupe
One cool mod is to use W210 dual-filament bulb holders and little bit wire and convert them to be tail / brake lights. I did and looks good.
Old Aug 31, 2014 | 06:16 PM
Nanook's Avatar
'18 GLE63S AMG /'19 PORSCHE TURBO S / '09 CORVETTE ZR1 /'14 LEXUS RX350/'16 RAV4 Ltd
There is only one rear fog light (drivers side) ..see manual. It's apparently for when you're parked on the side of a road and is ued to mark the proximity of the vehicle
Old Aug 31, 2014 | 07:36 PM
Chadzu's Avatar
2001 Clk55 AMG
Make sure your license plate lights are working, they will trigger the error message.
Old Sep 1, 2014 | 12:35 PM
City Rat's Avatar
Veteran: Army
Ok but I have two bulbs on the drivers side and one on the passenger side...
Old Sep 1, 2014 | 12:36 PM
City Rat's Avatar
Veteran: Army
License plate holder lights are good. Thanks, good looking out though. Appreciated.
Old Sep 1, 2014 | 06:19 PM
cindyclk's Avatar
You said that error comes on when you activate rear fog light....since that is when it comes on, the culprit is the driver side for bulb.
I assume that the error does not come on when you have just the main lights on??
Old Sep 1, 2014 | 06:35 PM
City Rat's Avatar
Veteran: Army
Actually no and perhaps my bad for not explaining it well. The check lamp error message comes on as soon as I turn on the main lights. I have checked headlights, high and low, no probs, tail lights, good, brake lights both tail and thee third one on the trunk, all good. Plate lights, nice and bright. This just left the fogs. Front fogs, fine, rear fog tail lights, the inner tails mounted on the trunk. Drivers side fine, passenger side, dark. That's when I noticed that I had two driver's side inner tail bulbs and just one on the passenger side. Hope that makes more sense. BTW I just went to autozone to get a replacement bulb but no one can read the number. Anyone know the part number for this bulb? Thanks.
Old Sep 2, 2014 | 03:17 AM
Chadzu's Avatar
2001 Clk55 AMG
Are the front park lights working? They are in the high beam housing. Just grasping at straws. My '01 has both left and right rear lights, switch lets me select either one.
