W209 CLK55 AMG HPS gen 2 complete!
Old 03-14-2015, 07:57 PM
  #51
cm60k's Avatar
00 C200 & 00 C55 & 06 SLK55
Is stock diff. 2.82 or 3.06..?
ZAYED,,
Old 03-14-2015, 07:59 PM
  #52
c32kompressor's Avatar
CLK55 AMG
ZAYED,,
I wanna say 2.82
Old 03-14-2015, 08:02 PM
  #53
cm60k's Avatar
Ahh, i thought its 3.06..!,
ZAYED,,
Old 03-14-2015, 08:09 PM
  #54
CLK55 AMG
ZAYED,,
I could be wrong though, has anyone ever swaped final drives with a c32?
Old 03-14-2015, 08:51 PM
  #55
tw2
tw2's Avatar
2005 E55 AMG, 1991 MR2
Originally Posted by c32kompressor
Yeah stock headers, stock sl intake, stock exhaust with 4 cats. I was thinking about porting the intake runners, they're pretty small.
I'm running stick diff and 265 wide tires on stock rims
Drag radials and a LSD will make a big difference getting of the line. Do you have a timeslip?
Otherwise you know exactly what the stock manifolds and downpipes look like. It appears to make a huge difference to stock cars so I imagine the response would be fantastic to yours. I wouldn't worry about porting the intake or changing the rest of the exhaust or secondary cats, I personally think these would be minor improvements. But unfortunately long tubes are probably the way to go.
There are plenty of roots supercharged cars with awesome timeslips all the way up to professional dragsters but when compared to turbos, centrifugals or even twin screws, roots are much more suited to providing massive low down torque. I am guessing that is why kleemann and hps chose the eaton unit, most people want the night/day improvement to everyday driving. Thats my view on it anyway.
  #56
cm60k's Avatar
I believe "C32/C55/CLK55/SLK55", all these using 3.06, isn't..?
ZAYED,,
Old 03-14-2015, 08:57 PM
  #57
CLK55 AMG
ZAYED,,
They may, but I thought the 32 has a higher than the w209. I could be wrong, I'll have to check into it.
Old 03-14-2015, 09:30 PM
  #58
cm60k's Avatar
Any video after your great mods..
ZAYED,,
Old 03-15-2015, 08:21 PM
  #59
CLK55 AMG
ZAYED,,
Not yet, ive been meaning to though
Old 03-16-2015, 07:02 PM
  #60
2MCHCAR's Avatar
Supercharged CLK500 & ML500
To add to this, it could be the racing technique. Could you share the technique you used when you ran your fastest run? Was dyno used, Burnout or not, ESP on or off, Transmission on C, S or M, did you hold certain RPMs at the line?
Beyond that, as far as Hardware, the LSD will give you the biggest improvement for the money ($1500-$2000). If you don't already have a TCU tune, get one so all the torque limiters are removed ($350). E55 Cams will get you 25 BHP ($300-$600) and Long Tubes should be worth 40-50hp ($3000+).
Old 03-16-2015, 07:06 PM
  #61
CLK55 AMG
My best 13.2 I was in M I did heat the tires, I held 1800 rpm. No spinning, 1.9 60 ft.
The car still has a lot of improvements to make for more power. I'm done with school Friday so I can have a little more fun with her now.
E55 cams were something I've been looking into
Old 05-03-2015, 02:25 PM
  #62
CLK55 AMG
UPDATE!
6k miles and no problems mechanically. I've been having some tuning issues, but things are soon back to normal with some other goodies. I bought a 2.6" pulley, bigger intercooler for the plenum and here in two weeks an aem water meth kit. I can't wait to get those installed and dial in the tune. She should be a monster. I'll update as things come up.
Old 05-04-2015, 07:54 PM
  #63
tw2
tw2's Avatar
Sounds awesome. What sort of tuning issues have you encountered?
Old 05-04-2015, 08:48 PM
  #64
CLK55 AMG
I had a dieing fuel pump that messed up my LTFTS, eurocharged quickly helped me get everything back to normal
Old 05-04-2015, 09:21 PM
  #65
tw2
tw2's Avatar
I thought you only just put a new walbro in? Was it faulty?
Old 05-04-2015, 09:37 PM
  #66
CLK55 AMG
Yes but sadly it failed. New one in and no problem. Hopefully this one doesn't die. It could have been a faulty unit from the factory.
Quick Reply: W209 CLK55 AMG HPS gen 2 complete!
