2002 clk55 amg cab code P0450
My CEL came on about a month ago. OBDII scanner produces code P0450 which translates to "fuel tank pressure sensor malfunction". My question is:
Where is this sensor located? How do I rectify the problem?
Please help!!!
Filler cap is known to throw a CEL though.
my friend had the same issue last year, he replaced that vapor valve & vent hoses, everything cleared,
before replacing the valve, check if there are any leaks on the vent hoses, that goes to the canister or canister vapor valve,,
this canister located on the driver side rear wheel, you have to pull out the plastic liner cover, you will see it hanging up there..
-;ZAYED;-
